I have attached a photo of the prop shaft in the lower hull. However, it does not look look like the photos I've seen. What am I doing wrong?????? Also, my 3.5" Subdriver does not have the hole drilled for the shock absorber indexing pin. How far back from the second drain hole is it????
Thanks.
I'm sure more questions are coming....
Farlan
Thanks.
Farlan
