USS BLUEBACK Bow & Aft Nose Removal
  • biggsgolf
    • Jan 2020
    • 733
    Hi,
    How far off do I remove these noses? I removed the lower hull aft nose past the nose as to allow the forward facing bearing to seat in the lower hull. Is the bearing to be sanded to decrease its diameter as well? I am concerned about having enough space between it and the Subdriver unit. It looks to me to be seated 3mm or so forward of the instruction photos.
    Thanks,
  • biggsgolf
    • Jan 2020
    • 733
    • biggsgolf
      • Jan 2020
      • 733
        • 12317
        I'm not following you at all. Try again, please.
        • biggsgolf
          • Jan 2020
          • 733
          David, sorry about that.
          When the kit arrives both the upper and lower hull have rounded ends that I assume are to be cut off. On the Lower hull in order to allow for the forward facing bearing to fit in the end of the hull I had to shorten the hull about 3mm more after cutting off the rounded end. I am calling whats pictured as the forward facing bearing. In the second photo, the upper hull still has the rounded nose which I later cut off, the lower hull shows the I cut off the rounded end nose, then cut off an additional 3mm since the forward facing bearing was to large in diameter to fit in the hull. Did I do as I was supposed to do is what I am hoping?
          Bruce
