Puffin - Trial and error engineering
    • 2627
    Yeah I think it's a typo, he has a 2200mAh in the picture so I'm going to go with that pack. that should give you a continuous current in excess of 10-15A or more, so I reckon your prop/motor combo is probably a bit overcooked if that battery is getting too hot.
    What's the motor size, KV, and diameter and pitch of the propeller?
    • Occupant
      • Jan 2025
      • 66
      Type-Ohhh damn... 2200mah
        • 2627
        Okay, so what's the motor size, KV, and diameter and pitch of the propeller?
        • Occupant
          • Jan 2025
          • 66
          D2830, 1000kv, 2” diameter, 3”pitch - 3 blades not the two blade pictured Click image for larger version
            • 2627
            That's your problem then. Huge amount of pitch at unloaded speed of 11000RPM+
            You want a motor around 300kv-500kv for a prop like that on 3s. It should still be rapid. or consider an inline gearbox of 2:1 or higher. Also consider reducing the pitch of the prop to square or less.
            Alternatively, with your existing drive train consider running a much smaller diameter and pitched prop, something around 1.5" diameter and 1-1.25 times pitch.
            • Occupant
              • Jan 2025
              • 66
              Thanks for the info, going to try a different prop first (only changing one part ) simple easy test doing with the 2" just as a oint ot start change the pitch and duration of the blades. pitch of .75 duration of about 130 degrees. while thats printing will look at using the 650kv motor i have in the peristaltic pump in the design se if it fits and if i can quickly just adapt the end cap vs having to do all the parts again. that way if the new prop improves things the slower motor would be another step in the right direction.
              should i read by your comment "11000rpm+" that your running full throttle? how does limiting the motor speed via transmitter effect the battery and ESC, concerned the throttling may generate heat in the ESC nd heat up the internal WTC cavity with the battery in it.
                • 2627
                Speed controllers whether brushed or brushless control speed by ‘chopping’ the current using a microcontroller to pulse it on and off. Generally the frequency of the pulses is in the thousands of hertz. With a brushless control the commutation is handled electronically, and handled mechanically with a brushed motor.
                The pulsing does create some losses in the system, as transistors take time to switch on and off, and in that time span they have a much higher resistance and therefore generate more heat. However modern transistors are so efficient and fast this is barely a concern.
                With the 11000RPM I’m basing that on full throttle. I would say for that motor you want a prop diameter of no more than 1.5”. For a a 2” prop running direct drive, I would look more towards a 35mm outrunner, but you’ll probably be okay with a lower kv 28mm unit. I’d look at running a simple two blade prop.
                • Occupant
                  • Jan 2025
                  • 66
                  Thanks for the info, i wanted to somehow quantify results and came up with a makeshift setup to get me better info. Attach the drive to a yardstick with a pivot, one end is the drive the other end a finger to push on a scale. Add to that telemetry giving current measurements. To start using ~2 inch prop - already have the mount for it. From there modeled and printed two props a 2 blade and a 3 blade - both with the same pitch. the two blade gave almost double the thrust with only 20% increase in current. Now starting with the 2 blade as a reference do another with double the pitch and then finally smaller 1.5 inch diameter to see what is the best balance of current and thrust .
                  Click image for larger version  Name:	IMG_0333.jpg Views:	0 Size:	92.9 KB ID:	197136
                  Click image for larger version  Name:	IMG_0337.jpg Views:	0 Size:	51.3 KB ID:	197137
                  FYI the throttle is being limited to 70% output via transmitter curve. I use the same 650KV motor for my ballast pump , limit it to 25% output and it draws a little over an amp. Anyone else measure current on your drive? what kind of current draw are you geting for normal running?
                    • 2040
                    Im my big Alfa, I was drawing 1.2A at cruise speed and 8A at full throttle. The Seawolf by Thundertiger draws 13A ful-tilt. Current consumption increases exponentially with speed through the water. I run the FAS40 current/voltage sensor for live telemetry in my personal boats.
                      • 2627
                      Alongside measuring current and thrust it’s also worthwhile measuring rpm if you have the capacity to do so. To get the best efficiency from your set up aim for a loaded rpm to be around 85-90% of your unloaded rpm. If it gets below 80% then the combination is poorly matched and you should either reduce the load by changing the prop size or look at some form of reduction, fit a larger motor and/or one with a lower kv.
                      • Occupant
                        • Jan 2025
                        • 66
                        Thanks for all the info
                        RPMs would be interesting , not readily done - my drivetrain is in the wet so optical is out, hall effects units would have to be waterproofed. FRSKY had an ESC that provides all the data RPM, V, A but not sure want to invest just for a quick measurment - kinda pricey.
                        "To get the best efficiency from your set up aim for a loaded rpm to be around 85-90% of your unloaded rpm."
                        Sorry if this sounds dumb but explain what you mean by loaded and unloaded At first blush i thought you meant dry vs wet, Dry i'm pulling .8 amps max speed tested (have output weighted to about 70%) that can't be what you meant by unloaded ?
                        Think i get the concept loaded vs unloaded the closer they get the higher the efficiency less work ont he motor and ESC. for example a square tire vs a round one, very inefficient under load. add facets and the square becomes a hex, and octagon and such until it approaches a circle and the efficiency of a circle.
                        FYI completed a couple more tests this afternoon, double the pitch - added 30% to current draw to produce nearly the same thrust. they i went half the pitch i started with and got a fraction of the thrust at a lower current. The peak so far seems to be with a pitch .75 of the diameter. Next test is smaller diameter with the 75% pitch see if it can come close to thrust and drop the current draw. will try first in the 2: tube then sleeved to a smaller closer to the 1.5" diameter see what having free space around it does.
                          • 2627
                          Loaded and unloaded is referring to the rpm of the motor running uncoupled in the air, loaded is in the water coupled up to the propeller of your choice. Also worth mentioning that a statically held propeller in a test tank will draw more than one that is dynamically moving through the drink.
                          • Occupant
                            • Jan 2025
                            • 66
                            Another day, another design, print, test.. more reading and googling.
                            Using the feedback here have a rough idea of what to shoot for. So far a 2” prop with a 1.5” pitch has had the best results so far putting out about 1.5 lbs of thrust with about 12 amps.
                            FYI tried a 1.5” prop in a 2” tube with odd results, throttle up forward and it goes reverse off to the side, reverse did the same - goes in reverse to the side???
                            After a while googling - started getting help designing a prop only to be corrected that it should be an impeller for a jet drive. something it suggested thru questioning is to have the impeller OD as close to the jet tube ID as possible to minimize blow by. Two simple changes made a huge difference in performance. first increased the length of each blade to complete the circle from the end view - no open free space, (traditional props have about 50% open area) same pitch as above. Second printed the impeller at 2” and sanded the perimeter until it was a slip fit into the tube.
                            his two small changes made a huge difference. Thrust went to about 3.5 pounds (21 amps, max throttle) - not seen in the pic is its bending the yardstick. Taking a couple other points hit 1 lb at about 3 amps, and from that what appeared to be decent flow but less thrust at about an amp.
                              • 2627
                              You're going to need some very good batteries to supply 20A with consistency. Does the shroud have some vanes to counter torque roll from the prop, otherwise handling might be interesting.
                              • Occupant
                                • Jan 2025
                                • 66
                                #30
                                The 20A is at max rpm, not sure i'll ever need that kind of power, a lower KV motor might be the answer - have gone from a 1000kv to a 580kv for this iteration. Anyone have history of using a slower motor ( one that doesn't come from a place that starts with Ali....
                                Ran the tests again trying to hit each amp 1,2,3,etc... as Bob said it jumps exponentially at a point. Also did something different, using reverse note when current moves the drive. in this case just blow an amp starte to get movement and just under two amps will pull the assembly to the surface and start sucking air thru it. need to put this into the boat, run it in the pool vs static testing to get a better feel.
                                The rudder ball has vanes in it in addition to the fins in the front.
