COMING SOON! 1.5" Sub-driver for small models
    • 14011
    Originally posted by Rogue Sub
    actually yes I can believe it but can you get the the proper shafts run and the right amount of foam and weight in there.
    It'll be a dynamic diver (no room for ballast tank or associated hardware). No sweat.
    • toppack
      • Nov 2008
      • 1124
      dynamic........dynamic.......Scary word that. ;)
      Rick L.
      • Nuke Power
        Banned
        • 277
        dynamic is very plausible then. you wont have to compensate for the pump weight and can use the space for battery. Will the surfaces be large enough to get the required force to dynamic though? The only way to compensate for inadequate surfaces is to either make bigger out of scale ones or to make the thing ballasted so low in the water it wants to sink but then if you go to deep you run the risk of it sinking out if you can power your way back up. I know Im am not talking about anything new to you but I am curious what you think. Also will you be using a wet brshless set up aswell?
          But you only refer to the Skipjack - having no ballast. The other models will Snort.
