Wtc
    • 13575
    Originally posted by Rogue Sub
    ps is that the 1/350 dragoon model cause i see mike doesnt carry it.
    I think what you're ragging on about is the Revell TYPHOON, Kevin.
    I'm dancing as fast as I can!
      • 13575
      Originally posted by pdrum
      Wow Merriman that's really awesome! Where can i get those sub-drivers taht small? and those gears? *really excited now and not dissapointed* haha
      The gears you see were cut from a brass rod that arrived pre-cut with the 48-pitch, 11 tooth gear pattern I use as pinions in my gear reduction units. I simply bore disks cut from that rod to the required size and attach them to the 1/8" shafts you saw in the pictures.
      You get those SD's from Caswell Inc. Soon ... very soon. As you can see, it's nothing to convert from single to duel-shaft arrangements in no time.
      • SteveJ
        • 56
        Would the new SD work in the trumpeter Gato kit?:rolleyes:
        • Nuke Power
          Banned
          • 277
          ive enver heard of a revell typhoon. Didnt come up in my internet search either.
          • toppack
            • Nov 2008
            • 1124
            Here's a 1/400th scale Revell Typhoon on eBay:
            Rick L.
              • 13575
              You betcha. What, pray-tell, is the diameter of that cylinder provided in the Trumpeter GATO kit, again?....
                • 13575
                Idiot!....
                • pdrum
                  • Mar 2009
                  • 6
                  yeah doesn't seem too bad. My set up isn't quite like urs, my propellers are on the ends of the planes. so i'd have to have a rod spining perpendicular to the WTC.
                  So you had a brass rod with teeth precut and u just cut slices of it? I see. Where can i get a rod like that cut like that? or would i have to have a rod then get someone to machine it? -_-"
                  • toppack
                    • Nov 2008
                    • 1124
                    You can get small plastic and brass gears, already made, at Smallparts.com.
                    They may have the gear-rod also.
                    Some have set-screws already installed.
                    Rick L.
                      • 13575
                      SDP/SI is the leader in the design and manunfacture of precision mechanical components, such as precision gears, gear assemblies, timing belts, timing belt pulleys, and couplings.
                      • toppack
                        • Nov 2008
                        • 1124
                        The gear-rod is the way to go if you can do the shaping, drilling, taping, etc. Yourself, since it's cheaper and they can be made to suit your needs, but if not then it's better to get them already made, from someplace like Small-Parts, which has high quality parts.
                        Rick L.
                        • pdrum
                          • Mar 2009
                          • 6
                          wow this helped a ton! thanks a lot guys =D anyone have plans for a wtc? =]
                          • SteveJ
                            • 56
                            well i guess i'll be dusting off my trumpeter gato kit, was waiting for this day to comeI'll drink to THAT!:D:D
                              • 13575
                              It's on my 'to do' list.
                              • toppack
                                • Nov 2008
                                • 1124
                                #30
                                I just figured out why David does Not have detailed Plans for his WTCs or Sub-drivers. If he did then it would be much easier for someone to COPY his creations and that would be Bad for business. :rolleyes:
                                Who said he wasn't a shrewd business man? ;)
                                Rick L.
