Seawolf/Seaview SubDriver motors
    • 2021
    Can anyone quickly tell me if the motors in the small Seawolf and Seaview SubDrivers will take 11v, or if I'll fry them. I want to step up the juice from 7.2 for more oomph! Oh, and I just happen to have the right size LiPo's here rather than having to wait on new battery packs...
    Thanks!
    • 13869
    No they won't.
      No they won't.
      Won't what? Fry or take 11 volts?
        • 13869
        Thanks, Mike. Yeah .... my flip response could be read both ways.
        Those motors are designed for 4-7 volts. Run them higher, and under a load and they will quickly burn out.
          • 2021
          That'd be awesome.. the Seaview raising a huge plume of water off her bow, smoke billowing out behind her..
          Ok.. maybe not. Point taken. ******. My new batteries won't be here until Friday, then I leave for two weeks to Italy. Sigh.
            • 2570
            Ain't life a b1tch!
              • 13869
              Indeed.......
                • 3721
                The Gato Sub Driver does take 11v, but the Seaview does not? help me understand the reason, was it because of the pump-jet efficiency?
                Tom
                  • 13869
                  Tom
                  Battery size, both physical layout, voltage and capacity -- at the time I designed those SD's, the currently available Lithium-polymer batteries -- drove motor selection. Now, some four years later, there are more choices.
                  The smaller SD's get the 7-volt motors, the bigger SD's get the 11-12 volt motors. The cart got ahead of the horse as to motor voltage selection. Simple as that. And that's the ugly truth.
                    • 3721
                    Thank you for clarifying. I understand.
                    • alad61
                      • Jan 2012
                      • 476
                      What are the specs on the motors in the seaview sd. It looks like I may have to replace one of them... :( Also it would be handy to get some spares...
                      Cheers,
                      Alec.
                      Reality is but a dream...
                      But to dream is a reality
                        • 13869
                        I'm on it. E-mail me your mailing address and list of what you need. I'll fix you up, Alec.
                        dmeriman@aol.com
                        • alad61
                          • Jan 2012
                          • 476
                          Thanks David. Email has been sent.
                          Cheers,
                          Alec.
