Help needed with Vex 6 channel receiver and transmitter
  • Michael440
    • Mar 2021
    • 51
    Hi, I have an Engel submarine I am building. However it looks like I need more channels then 6. This is what I have. 2x speed controllers for the motors. 1x servo for the rudder. 1x channel for the twin dive cylinders. This leaves me only 2 channels remaining. Yet I still have front and rear dive planes, and an Engel trim, LTP6 control that needs a prop channel and a switch channel to function. What can I do. And I have no idea what a prop channel is. Can anyone help. Thanks
    • 13984
    Start hunting around for an old Futaba 9C series transmitter and matching receiver on the 75 or 72mHz band. Or (gasp!) use a more capable 2.4gHz system and resign yourself to never diving (intentionally) below periscope depth. BORING!!!....
    The VAX ch-5 and ch-6 are non-proportional, which leaves you with only four proportional channels on that transmitter. Not suitable for all the bells and whistles on that overly complicated model currently cluttering up your workbench.
    Do you really need differential control of the two shafts? I wouldn't bother if it was my boat. Just gang the two motors to one ESC and be done with it.
    KISS!
    Crusher of High Hopes and Lofty Intentions
    • Michael440
      • Mar 2021
      • 51
      Thanks. I am in the U.K. and getting 40mhz radio gear is getting very hard these days. If I go 24mhz, I understand that I need to keep the aerial clear of the water. What if I attached to a float of some kind. Something that looks like a small lifeboat let’s say. Would that work. How long can I make an aerial. Thanks.
        • 13984
        I assume you meant 2.4gHz, not the 24mHz you wrote. Yes, you can extend the receivers 1.25" 2.4gHz antenna to a 'float' with some coaxial cable. But it will look like hell and will eventually foul around all the spike-like projections that are the GATO's periscope and antenna shears.
        Find some used Futaba 9C gear on the 40mHz band is my recommendation.
        Is this your first r/c submarine? If so, you have chewed off way too big a bite! Get a smaller boat the VOX system can handle.
          • 13984
          Or, you can stuff the 2.4gHz antenna into one of the periscope heads. Like this:
          How To Adapt The 'New' 2.4gHz Gear To R/C Submarines - The Sub-drivers Forum (rc-sub.com)​
          • cheapsub
            • 193
            You can try this , is up to you
            • Sinksalot
              • Mar 2020
              • 365
              Easy one one, Buy these three items:
              https://www.ebay.co.uk/itm/234971957116
              https://www.ebay.co.uk/itm/155506683273
              Dave
              • cheapsub
                • 193
                That's convenient and affordable.
                That's going to be hard to unload my junk.
                16 channel any one.
