What boat am I?
  • Warpatroller
    • Dec 2012
    • 90
    What boat am I?
    David was talking about sweeping up the shop with a broom the other day..
    Well here is a boat with a broom sticking out of it..
    What boat am I and where am I? Said this rather large piece of submarine history. This one is probably too easy..
    "Wir kommen ihnen unbekannt."
    • 12256
    The Memorial in Groton?
    • roedj
      • Sep 2008
      • 562
      SS383 - Pampanito
      Dan
        • 3545
        USS Drum, Mobile, AL.? I do not think they put a broom on their sub, probably USS Pampanito.
        • Hazegry
          • 37
          not sure what sub but the broom means they had a clean sweep of sea trials and are ready to come out of the yards. The broom is usually flown on the way back in to port.
          • roedj
            • Sep 2008
            • 562
            ss383 Pampanito with picture...Click image for larger version
Name:	383sail Pamapnito 003.jpg
            Dan
              • 12256
              Maybe today. But in the time of these boats (pre-GUPPY converesions) it means return from a successful War Patrol.
              • Tugfan
                • Nov 2010
                • 178
                The DRUM in Mobile is a rust bucket. They ought to be ashamed. The rear torpedo area is almost completely rusted away.Click image for larger version
ID:	76953Click image for larger version
                  • 12256
                  Rode hard, put away wet. The Navy leases these on condition of reasonable preservation and respectful presentation. What the hell happened here?????!!!!!!
                    • 3545
                    What I was looking at was the round antenna, RDF. It is mounted upside down. The Drum, albeit a rust bucket, has the same setup as the one pictured.
                      • 2848
                      [ATTACH=CONFIG]19727[/ATTACH]
                      OMG! Yep! That's the one he uses! It makes you ill to think where he's had that handle!
                      I prefer The British answer, the Jolly Roger!
                      • Scott T
                        • May 2009
                        • 378
                        This photo said taken may 2012 of USS Drum. Looks like some work has been done.
                        • Warpatroller
                          • Dec 2012
                          • 90
                          Pampanito it is! In San Francisco! I was on board her in late March.. Took several photos, here are a couple..
ID:	76957 Click image for larger version
                          • Kim Sleep
                            • Nov 2013
                            • 329
                            Man, that broom is gonna be hard to replicate when it comes time to make a model of it!
                              • 3545
                              What? You're a resourceful guy. Get a .003 inch drill bit, make 800 holes real close together, shave a bit off the cat (and dye it a straw brown), then CA each one in individually. If you do not have a cat, while the wife is sleeping, just snip the ends of her hair, you may have to ream the holes a tad to adjust for the thicker hair size, but that should work. What's the problem with that? jk
