X-Craft RC options
  • Slats
    • 1776
    #46
    Alan's 1/12 scale boat was a bit too big for my tastes. A modeller over here scratchbuilt a lovely little 1/24th scale x-craft which I always thought was a perfect size.
    Originally posted by Kazzer
    I'm inclined to agree. It's a big boat as per Alan's spec.
    So Mike, what size have you settled on for your Vac formed X craft?
    sigpic
      It's the same one I've always said I'd do, because I have permission and a hull to use. 1:12
      • herrmill
        • 360
        #48
        Yea, shame its not a tad smaller... 1/24 would be the sweet spot & go nice beside that Seehund I'm currently building.
        • Slats
          • 1776
          #49
          I'm having discussions next week with a guy over here who I recently commissioned 3 new GRP target hulls from regarding him doing an X craft in either 1/20 or 1/24 (including side cargoes). I have an excellent set of plans in 1/24 that came with a book, I bought from Mike a couple of years back called Midget Submarines of the Second World War.
          Here is a link:
          I don't want to create vapourware but I'd be keen to know if there is interest in an X craft this size. At 1/20 or 1/24 you could probably get away with being a dynamic diver or having a tiny BT as there is very little free board. It might not be practical to accommodate SAS, but could accommodate a simple LPB / vent system for the ballast with a positive buoyancy setup.
          sigpic
            • 2407
            #50
            The main market is going to be Australia and UK, with maybe a handful elsewhere. Not popular in the U.S or Europe.
            UK modellers are likely to say-too small and fiddly. I think with todays equipment that is moot, but old habits die hard. Might have some appeal as a static kit.
            X-craft work well as dynamic divers, but will need higher than scale speed to submerge under power. They would only need a ballast tank of about 100ml.
            • Slats
              • 1776
              #51
              So Andy do you still feel 1/24 is "perfect size"? I'm leaning towards getting this done in 1/20 purely based on the knowledge of what Subdriver products I could throw inside it. But I'm not sold hard and fast either way. Thanks for the heads up on the dynamic dive issues. I think I'd be going small vented tank with LPB from the Subdriver range.
              I know Chuck said on this thread awhile back 1/24 he'd like.
              J
              sigpic
                • 2407
                #52
                Your boat, do it to the scale you like.
                1/24th is a little mroe conventional, I guess the Seehund Chuck is talking about is the RPM one, which is 1/22nd scale, so 1/20th would be closer in some respects. The little delphin I'm working on is 1/24th- diddy little boat at that scale.
                Think you'd do well to design the boat so it could be configured as a dry hull or wet hull.
                • Slats
                  • 1776
                  #53
                  Thanks Andy, I think I'll keep it simple, which is what I know and a wet setup.
                  Cheers
                  J
                  sigpic
                  • Slats
                    • 1776
                    #54
                    1/20 it shall be. It will take the 2.5" Subdriver. It will be small enough for practical pool use, and still sizable enough for shore line patrols at the lake.
                    I let you know how I get on. I am certainly not toting for business for a new kit. My motivation here is getting one done for me, but it would good to know if others would be interested.
                    just one question re the side cargoes. I am thinking that its probably best if these are removable, rather than a fixed extended part of the GRP hull? Andy and others in particular, do you see this as the best way to proceed?
                    Also re the plans in the book that are also found on Mike's site too below - are these accurate enough?
                    John
                    sigpic
                      • 2407
                      #55
                      Most working model x-craft I have seen don't have the side cargoes fitted, an exception were the superb miniature x-craft built by an expert modeller back in the 80's. Those models benefited from the extra girth and buoyancy offered by the side pods. My thoughts are that by lowering the aspect of the submarine, they are likely to improve the turning circle at the expense of a slight increase drag- would be interesting to do an A/B comparison to see how that pans out in practice.
                      I would certainly have them as an independent part however.
                      Regarding the Paul Kemp plans in the book you mentioned, I have the same book. I don't think the plans are 100%, but I'm not an expert on this craft. What I can say is that the Seehund plans on the flip side have several mistakes.
                      The very best person to speak to about X-craft is Alan Poole. He made the large 1/12th scale boat, and did a great deal of research into this craft.
                      • Slats
                        • 1776
                        #56
                        many thanks Andy
                        J
                        sigpic
                          The model I have was originated by Alan Poole and he gave me lots of photos too. They are on the web page.
                          Unfortunately, there are many problems with the museum piece which has been restored hastily, it seems, so that isn't a reliable source of information.
                          Alan told me the model I have demonstrates the accuracy of the original boats, but I don't have any info on the actual bombs.
                          • Slats
                            • 1776
                            #58
                            Thanks Mike,
                            I'll proceed with caution, but I'll make use of the plans I have within the book I bought from you, as the main source of information.
                            Best
                            J
                            sigpic
                              Thanks Mike,
                              Best
                              J
                              I think the book you refer to is by Kemp, and it isn't terribly accurate.
                              • subkraft
                                • Oct 2009
                                • 28
                                #60
                                I'm putting my hand up for an x craft hull.....
                                The Kemp drawings.....I seem to recall reading somewhere that the drawings are an accurate reproduction of the restored x craft at Gosport. Problem being that it had been inaccurately replated at some point.
                                For what its worth....
