Yeah ... Peter ... you do that.
Assembling the Arkmodel 1/72 KILO kits ... that's right: kits!
Peter, YOU could ask him again in a couple of weeks. Let me know how that works out for you. HA!Leave a comment:
Pity and a shame...
[ATTACH=CONFIG]30485[/ATTACH][ATTACH=CONFIG]30486[/ATTACH]
[ATTACH=CONFIG]30487[/ATTACH][ATTACH=CONFIG]30488[/ATTACH]
I suppose a regular one is OK.....sigh
[ATTACH=CONFIG]30489[/ATTACH]
Let me know about the plans though Mr. M
Peter
P.S. Thanks for the support Mark ! ........Running away!
I so love it when the troops start throwing each other under the bus!
Nice pictures.
I already made a Project-636 propeller in 1/144 for the TRUMPTER kit. Now I gotta do it again for Feng's kit. Grrrrr!
MLast edited by He Who Shall Not Be Named; 03-18-2015, 08:54 AM.Leave a comment:
Do you think ARKMODEL is a reliable supplier? Cause some people (not me; I've lerarned a little) have had the same bad experience with him with than with Mr. Palumbo.Leave a comment:
AH Well its was PETERS fault......Not Mine...................HE WAS THE ONE who suggested it......right peter?(as im slinking away to my corner)No. Sorry for the confusion, Mark. The model pictured with the many stator blades is the OTW 1/100 VANGUARD I assembled for a customer -- I manufactured a new sail, control surfaces and pump-jet. Those enhancements were reduced to tooling I sent to OTW to up-grade their kit. Pushy *******, ain't I?!
The pictures presented only to further demonstrate the use of metal straps to hold parts till they can be permanently bonded in place.
Nooooo, I will not convert to the ALROSA. You nut! I'm assembling these kits stock (other than making a proper propeller). No, Caswell, as far as I know is not marketing these kits. But, to be sure, check with Mike directly on that, Mark.
MLeave a comment:
I have one of these kits available in Sydney if Mr C is out of stock. Purchased it two years ago and I don't look close to getting it done (wrong scale for me as well). At cost plus postage.Leave a comment:
MLeave a comment:
Mr. M did the kit come with plans? I do have a set of plans for an 877 if you need them, I also have some good drydock reference shots if required.
PeterLeave a comment:
I must have mis-understood. I thought that these pictures of the pump jet(above attached)....(and pictured below) were part of the Kilo kit.[ATTACH=CONFIG]30370[/ATTACH] [ATTACH=CONFIG]30371[/ATTACH] [ATTACH=CONFIG]30372[/ATTACH] Yes, very useful when you have to hold assemblies together as you affix GRP re-enforcement on the inside. Here is another example of using brass straps to hold sub-assemblies together before bonding them permanently.
YES,YES.............I vote for the Alrosa. So your saying that Caswell will not be a supplier?Leave a comment:
Yeah, they went nuts with the bags. A good thing: better too much packaging than too little!
I have never seen a pump-jet with such a high inlet/nozzle area ratio! WTF is going on in there? I've seen yard pictures with a rotor and stator, but that only leves me wondering if there were multiple rotor-stator stages in that tunnel looking shroud. It appears to be the later Project-636 desgin of the KILO, but kept in national service -- not exported. Or ... so I've read.
Good catch. NASTY! Just the way I like 'em.
Stop tempting me with this neat **** -- I'm falling behind again!!!!
Oh, here's a video of a Trumpeter 1/144 KILO kit at the pool for you:
MLast edited by He Who Shall Not Be Named; 03-17-2015, 10:16 AM.Leave a comment:
lovely looking kit, bit anal with the bags though. If you are having to make new props why not go whole hog and build the Alrosa ?
Look at all that green stuff, you'd love it.
