What if?
    • 3454
    What if?
    What if you combine a skipjack type hull with a seawolf pumpjet, a cutdown or Alfa type sail, and maybe a X-tail, wonder how she would perform?
    • 2493
    Like a Dragonshark.
      • 13610
      What if you combine a skipjack type hull with a seawolf pumpet, a cutdown or Alfa type sail, and maybe a X-tail, wonder how she would perform?
      Been done, kinda. It's called the ALBACORE, phase-4. Not a proper pump-jet, but did feature the bit more efficient counter-rotating propeller (which, like a pump-jet, works to recover much of the swirl energy lost with a single propeller).
      My friend, Kevin Rimrodt, and I did a Y-tail conversion of a 1/96 SKIPJACK, as well as a radically new type of sail. That was about 20 years ago -- we've yet to get it into the water.
        • 3454
        A Y-tailed Skipjack?
        What was radical with sail you made?
          • 13610
          Kevin came up with the idea that too limit vortex shedding contact with the sail (which occurs near the boundary layer) -- a component of 'snap role' -- he came up with a sail design where the masts and bridge were up high in a sort of 'gondola' which connected to the hull with a very narrow, and short of cord, connecting dorsal.
          • Nuke Power
            Banned
            • 277
            Lets see a picture david
              • 3454
              Guess what I found in my old e-mails. These were given to me by Greg Sharpe in 2005. It's his scratchbuilt Russian Beluga class SSK. He used a 1/96 Skipjack hull.
                • 3454
                Can you show us how did you duplicate the counter-rotating propeller mechanism?
                  • 13610
                  Don't have any shots of that. One motor drove the inner shaft, a second motor drove the outer shaft through a gear drive. That simple -- two un-coupled motors, each driving one of the two concentric shafts. Dirt simple. And the propellers naturally load-match to produce a zero net torque on the vehicle. Slick.
                    • 3454
                    KISS. BTW, was the inner shaft a direct drive or geared?
                      • 13610
                      The inner shaft was direct drive, so was the outer -- in effect -- the two gears used to make up to the outer concentric shaft were of the same diameter.
                        • 3454
                        How did the model perform with the contra-rotating set-up?
                          • 13610
                          scary fast
                          • Nuke Power
                            Banned
                            • 277
                            Did it out perform the skipjack?
                              • 13610
                              When I tried to get up to SKIPJACK speed the ALBACORE got too squirly for me to drive. No, never sustained a SKIPJACK flank bell with the ALBACORE, but it had the ass to do it.
