A Question for the Wise One Who Shall Not Be Named
  • george
    • Dec 2010
    • 731
    Hello Sir.
    I have a rather small side project as a distraction from my main sub project. I have a R.C P.T Boat that I would like to have Launch tube torpedoes from it.
    What I thought is that I make one copper pressure tank for the propel and then with the use of a servo and switches move the servo one direction and one torp. is launched then move the servo the other direction and the other switch is triggered and the other torp. is launched. I would like just a fast blast of propel to expel the torp. and not empty the pressure tank after both torps. are launched. The copper pressure tank is to only hold the gas to push the trop. out of it`s tube and the torps are electric powered.
    How could this be done? Pictures, drawings any help would be appreciated. Space is an issue, working on a 1/35 class of boat.
    Thank You.
    George
    • 13711
    What you need is a 'poppet-valve'. It administers a short blast of compressed gas. Just what the doctor ordered.
      • 3528
      How about using springs to eject the torpedoes instead. More compact and simpler.
      • george
        • Dec 2010
        • 731
        Hello Again Wise one
        Thank You for your time and help. A further question on this subject. To make sure I understand the setup. One main brass propel source, two lines coming from it to each poppet valve and from each poppet valve a line to the torp. tube holding the torp. When pressed by the servo arm, the poppet releases a burst of gass to push the torp. out and on it`s way. The poppet is momentary, if the servo stays pushed on it, it will NOT empty the main propel tank like a spray can being held on?
        Where can I get the poppet valve and pressure cable small tubing and extras?
        Thanks Again for your Help.
        George
        • george
          • Dec 2010
          • 731
          Hello redboat219
          The problem with the spring method is it is mechanical and something is needed to hold the torp. in the tube until launch and more chances a breakdown. Also there is no visual effect or sound of torp. being fired.
          Thanks for the idea though.
          George
            • 3528
            Manfred (MFR) uses spring to fire off his e torpedoes from his 1/35 Type VII and Type XXIII Uboats.
            The gas ejection system is more complicated and has more chances of breakdown than a mechanical system. You already have stated one problem with the gas system.
            If you're after the effects how about using a small amount of gunpowder behind the torpedo. Same thing they used on the 1:1 boats. Simple servo activated on/off switch to fire off the ejection charge.
            • george
              • Dec 2010
              • 731
              Hi redboat219
              Little problem with the black powder, police here in Canada would NOT be too happy with me.
              • george
                • Dec 2010
                • 731
                Hello again o wise one.
                Could you please tell me if I understand your "poppet valve" suggestion? If I understand it, I need ONLY one poppet valve, I guess that is a 3 way poppet valve? I port for gas in and two ports for output? As the servo pushes the button a little, one output port fires momentarily then as the same servo pushes the button further inward the second port fires momentarily.
                Is that right? OR what do I need to launch two torps. one at a time?
                ALSO what type of SMALL Poppet valve do I get? What is the brand name / type?
                Where can I get one?
                Thanks again for your help.
                George
                  • 13711
                  George
                  No. You need a dedicated poppet valve per tube. Trouble is (I've been searching the Internet) I can not find one small enough for us -- likely the Froud numbers work against us as we reduce the size of the mechanism.
                  Try this: a dedicated 'impulse bottle' per tube, using a modified Schreader-valve as a firing valve. As you said, a single servo, tripping a firing-valve at each extreme of servo travel will work the two tubes. The impulse bottle being no more involved than a longer than normal flexible line between charge fitting (another Schreader-valve) and the firing valve, as all you want is enough impulse to poop the weapon out the tube, not launch it into orbit. I think this is your best bet.
                  The modified Schreader-valve (firing valve) looks like this,
ID:	91452Click image for larger version
ID:	91453Click image for larger version
                  • Sublime
                    • Jan 2014
                    • 48
                    There are tiny .22 RF blanks called ACORN, various reloading components called primers for pistol and shotgun. The problem with that is you need a firing pin/hammer. Remington Arms Company used to sell electrically fired primers at one time, don't know if they still do.
                      • 3528
                      Ok. How about using a solenoid valve like those from Clippard or RC-Subworkshop. Another alternative is those spool valves used to work rc aircraft landing gear retracts. Robarts is a well known brand.
                      • george
                        • Dec 2010
                        • 731
                        Hello
                        A PM has been sent to "He Who Shall Not Be Named"
                        George
                          • 3678
                          George,
                          Do you mean a real PM from the forum or an email? cuz, I do not think M uses the PM portion of the forum.
                          tom
                          • george
                            • Dec 2010
                            • 731
                            Hi Tom
                            I sent M a PM through the forum. I will try an email also.
                            George
