Can a centrifugal pump evacuate a closed tank?
  • roedj
    • Sep 2008
    • 564
    Other than these are one-way pumps, no problem using it (them) this way. Use either two pumps or employ a re-direction valve to select direction of flow between forward and after trim tanks. Run a vent balancing line between the tanks so you don't get any air compression/vacuum issues within the tanks as they fill/empty.
    Do'able. But .... why? Another Plumber's nightmare.
    DM,
    As usual, you're right. It would be a plumber's nightmare.
    Bad idea.
    Dan
      • 13988
      Originally posted by roedj
      DM,
      Bad idea.
      Dan
      You people!
      • Slats
        • 1776
        You people!
        Indeed - there is pushing the envelope of what has been proven to work = innovation.
        Then there is rehashing the firmness of the earth = re-examining the virtues of Rube Goldberg.
        sigpic
          http://pump-flo.com/pump-library/pum...-the-flow.aspx
          From what I've read so far. The pump would stop pumping and get vapor locked or cavitate when operated against a closed head.
            • 2642
            For precision of trimming it's really impossible to beat a piston tank. If you look at Romel's earlier link that shows a boat which incorporated a small servo actuated piston trim tank slotted within the main ballast tank, so not essential to go down the path of having a large piston tank for main ballast and trim.
            Generally a trim tank should be sized to equal about 1% of the boats overall displacement, plus a few grams if you want to make the boat go negative. Water only varies in density by 1% depending on temperature and mineral content. Most model submarine ballast systems tend to equate to about 10-15% of the boats overall displacement, so 10-15% of that tank gives you about the right size tank, but be careful if you are dealign with something with large freeboard, else you end up with a larger trim tank than you really require.
              Windshield washer pump/closed tank ballast system
              A nice build of Revell's 1/72 Type VII utilizing a windshield washer pump/ closed tank equipped with a pinch valve at a Spanish site.
              Crude but effective.
                Micro drain 12v pump for air or liquid, including fuel. In and out put. Most likely needs a capacitor, and a reverse polarity connection for R/C use and dual purpose suck and blow +<-----> -Click image for larger version
Name:	Micro-Drain-Aquarium-air or liquid-DC12V-200ml-per.jpg
