Advice Help Needed
  • george
    • Dec 2010
    • 731
    Advice Help Needed
    Hello to the membership
    I am in the planning, thinking stage for now. I would like to try to build the disney nautilus submarine for future r.c use. I see that it`s hull is of an octagonal shape and tapers to the front and rear.
    I thought about making several temporary octagonal bulkheads to attach the side pieces to. I was going to make each side piece out of epoxy/fiberglass and lay up the strips on a piece of glass since I heard that epoxy does not stick to glass.
    My question here is, since the nautilus is tapered to the front and rear, how do I get the stiff level epoxy strips to bend towards the front and rear without breaking? I was thinking about using a hot air gun to heat the sections were the strips had to bend BUT I don`t know if that would work.
    Anyone have this kind of experience with cured epoxy bending? OR how should I do it? As for buying an already Nautilus kit, if I could afford it and the S&H to me here in Canada was cheap, I would BUT since it is not cheap and S&H is nuts, I can`t so I try for now by myself.
    Thanks for your time and help.
    George
    • 13672
    .020" thick G-10 and a hot-air gun.
    • george
      • Dec 2010
      • 731
      Hello He Who Shall Not Be Named
      Thanks for your reply BUT what is "thick G-10"???
      George
        • 13672
        preformed sheets of epoxy-fiberglass plastic sheet.
        Huge Selection of G10/FR4 Glass Epoxy Sheets In Stock & Cut-to-Size from ePlastics. Fast Shipping. Trusted for Over 100 Years.
          • 2511
          Thin epoxy sheet like Dave recommends works as easy as thin plywood, so you can bend it cold too.
          • george
            • Dec 2010
            • 731
            Hello ALL
            I would like to thank everyone for their tips and I have decided to scrap my plan and to buy a pre made hull. After reviewing ALL the work and the fact I can`t physically do that work because of my health issues. I will start saving up for one.
            Anyone care to give me sources for a 1/69 Nautilus hull and who you recommend as a person to deal with.
            George
              • 13672
              Get a Brodeen hull. Bob Martin is the guy to deal with. Caswell offers the SD for it.
              Not a beginners project!
