calling the nameless one
  • satlite440
    • Jul 2012
    • 177
    waiting for the crack of thunder from the nameless one....please have a look at the progress so far on "im back "for satlite440's vIIc..
    looking for comments on
    1 weight amount
    2 klicon attachment to subdriver pushrods (what does the god recomend so if a pushrod seal ever had to be changed itcan be done without cutting the pushrod...)
    3 what lipo charger does hwsnbn use/recomend....
    4 any shot other than the qucik vidio any pics of the ft bowplane linkage?????
    i will here and obey.....
    • 13980
    Gotcha. Got some shop chores to clear out today. I'll get back to you tonight. Promise. Thanks for being patient with me.
      • 13980
      1 weight amount
      OK, here we are, fresh from the Cave ...
      1. about ten ounces total
      2. CA, as the guys recommend -- you can break the bond with a twist, scrape off the CA residue so you can slide the pushrod through the bad seal
      3. Don't like the one I got so won't recommend it. Let's look .... this one looks promising, http://www.horizonhobby.com/products...er-THP610CACDC
      4. Click image for larger version
ID:	81250Click image for larger version
ID:	81251Click image for larger version
ID:	81252Click image for larger version
ID:	81253Click image for larger version
ID:	81254Click image for larger version
ID:	81255Click image for larger version
ID:	81256Click image for larger version
ID:	81257Click image for larger version
ID:	81258 Sorry, best shots I got.
      • satlite440
        • Jul 2012
        • 177
        thanks dave i will keep you posted as i get along.. thank you very much shane
          • 13980
          Shane
          How is that ballast sub-system servo stuttering going? Still there. We recently identified a bunch of bad 2" SD motors. You might be having that problem. What's up on that front? We're working China right now trying to get in a good batch from another vendor.
          • satlite440
            • Jul 2012
            • 177
            THANK YOU FOR REMEMBERING your customer assitance is the best.........it is still present with the ballest servo, after the esc replacement but it was greatly toned down.. it takes over 3/4 throttle now befor it acts up. i thought it was about the best it would get,and i was awaiting to see if you found the issue.. and since we still havent bought the shop an occilascope yet (almost a must for diag modern cars) thats was as far as i could go with diag..but it would show if stray voltage feedback was being absorbed by the esc and backfeeding down the signal line...........
            is there a full fixx for this?????
            btw will you sell a moter bulkhead with moters/servos/ seperate???? how much??? i want to see if i could squeeze in a pair of action electeronics micro esc's with the mixerbord for shaft controll.. to try out in one of my 2 subdrivers...
              • 13980
              That attempted fix on your poor motor bulkhead haunts me still! I think (and you suggested this from the start, but I was so, so much smarter than you, and missed it!) you have one, maybe two of the bad lot motors Mike and I discovered recently. Chinese junk!
              So, you want a 2", two motor bulkhead decked out with everything but the motors? You'll need pushrod and shaft seals, seal foundations, and the like. Sure. Blast me an e-mail with your address. Give me the specifics of what you need, Shane.
              • satlite440
                • Jul 2012
                • 177
                sent email through the bord don't know if you got it ,lost your e-mail contact. but mine is satlite440@comcast.net
                  "So you want a 2", two motor bulkhead decked out with everything but the motors? You'll need pushrod and shaft seals, seal foundations, and the like."
                  Excuse me waiter, but i'd like to order the same thing he's having.
                  • satlite440
                    • Jul 2012
                    • 177
                    [QUOTE=redboat219;27411]"So you want a 2", two motor bulkhead decked out with everything but the motors? You'll need pushrod and shaft seals, seal foundations, and the like."
                    Excuse me waiter, but i'd like to order the same thing he's having.[/QUOTE
                    gonna try a mixer??????????
                      nah, I take my lambanog (coconut moonshine) neat.
                      Want to fabricate my own Type VII SD. Just need a length of 2" OD polycarbonate tubing and motor endcap.
