The SD From HELLLLLL!!!!!!....
    • 13991
    ... Anyway, some of you are going to think so.
    I'm soon to fill my first order for the new 1.25" 'dynamic' Sub-driver kit. A shot of the supplied elements of that SD pictured below
ID:	102198Click image for larger version
    A relatively new development (eighteen-months old ... new to me!) was Mike's identification of a source for those microbe sized servos used in the little ultra-light aircraft that have been on the scene for a couple of years. By employing these very small servos I free up a lot of space within the cast resin servo box, at the center of the SD. by cramming some of the devices within the servo box, along with the servos you'll be able to shorten the SD length as compared to the SD employing the micro sized servos -- this permits installation of the SD within the smaller little plastic model kits. As initially conceived, the servo box would only accommodate the much bulkier micro sized servos, as seen below.
ID:	102200Click image for larger version
    Problem is that the microbe sized servos have projecting mounting pads, elements of the PC board that comprises the foundation for all mechanical and electronic items. Pads, that prevent side-by-side use of the servo within the servo box -- the pads get in the way. Trouble is, that at one end of the PC board that set of pads has routed around their perimeter, conducting foil, both sides of the board. Cut off those pads and you clobber four circuit runs! Trouble is, you gotta get rid of the pads, and that means you're in for some SMT caliber soldering as you lay down some small gauge conductor to restore the circuit paths interrupted when you chop off the pads.
    You potential customers up to it?
    Here's what you have to do:
ID:	102202Click image for larger version
ID:	102203Click image for larger version
ID:	102204Click image for larger version
ID:	102205Click image for larger version
    Being a 'dynamic' type system, this SD does not have a ballast tank -- you'll have to trim your little Revell/Monogram/Aurora/Ace/Lindberg/whatever plastic model submarine kit so that it floats with only the top of the sail sticking out of the drink. I'm sending the first ten of these out to Caswell Inc. this week. I then (after I get out of a lot of stuff I owe Mamas, Bill, Jim, and others) finalize the design, complete production tooling, and sell Caswell the 'static' version of the 1.25" Sub-driver.
    Screw it, I'm going to bed!
    • 2642
    Is it not possible to stagger the servo's so that one set of lugs overlaps the other, then make one magnet lug a little taller so they both come up to the same height?
    Or is that still too wide?
    Also this-
    Hobbyking - the world's No1 Online Hobby Store. We stock a huge selection of RC products from Planes right through to Drones and all accessories. Visit Us Today.
    • small sub guy
      • Dec 2009
      • 45
      I bought an eariler version of the SD without the magnet for the servo, floor, spacer for pump end cap and the wall for water containment. Click image for larger version
Name:	2013-03-03 10.55.04.jpg
      So when I saw the SD from hell, I must agree. One down two to go.
        • 13991
        Also this-
        [ATTACH=CONFIG]19058[/ATTACH]
        http://www.hobbyking.com/hobbyking/s...ear_Servo.html
        Andy, you da man!.... always thinking. But, yeah, I tried staggering every which-way, but the tabs have to go. But what's this, two servos on one board! Neat! But I don't want to burden Mike with more stock.
        Hey, Mike: get two of these dual servo boards in for me to test, please.
        Thanks, Andy! Always there to help.
          • 2642
          Another thought. Would it not be better to retool the compartment to incorporate the extra width of the servos, so you don't have to modify them? I think if the builder has to tinker at electronics level it's going to put them off big time.
            • 13991
            Yes, that's the obvious solution, but would negate use of the system in the little Revell SKIPJACK -- it's that tight. And you're spot on about the need of the end-user to solder the bridges being a likely deal-breaker for some. Damn!
              • 2642
              Ah, okay- I didn't realise you were going for the static dive option for that tiddler too.
                • 13991
                A bit of an update: I've finalized the 'dynamic' type 1.25" Sub-driver kit. here are some shots of it.
ID:	76585Click image for larger version
                • Scott T
                  • May 2009
                  • 414
                  What if you mounted these on edge with a rod and magnet.
                  This would keep from cutting the tabs and needing to solder.
                  Scott T
                  Last edited by Scott T; 07-18-2014, 12:30 PM. Reason: Could not get sketch to show so made a post in gerneral section.
                    • 13991
                    That'll work.
