When will the Skipjack manual be ready?
That's not what I asked. The sentence makes no sense. What is the channel for? Also, there are no screws long enough to go through the SD restraining strap foundation to the hull. There is also no mention of its placement or pictures of it placed. The strap foundation looks taller than the rear foundation and would cause the SD not to sit in the rear cradle. Gluing the shock absorber is overkill. If it breaks you would have to grind it out rather than unbolt it. Lock tight should keep the screws from coming lose.Last edited by Tugfan; 11-28-2012, 08:00 PM.Comment
The strap foundation piece is secured by running the securing screws up through the hull and into the threaded holes of the foundation. Tall end of the strap foundation forward. As to location of the strap foundation, look at the pretty pictures.
Glue the damned shock-absorber in place!
Mike: you watching this? Tugfan is identifying some weaknesses in our manual text that needs fixing.
DavidWho is John Galt?Comment
And try really hard not to get verbal diarrhea this time!
Good grief!Stop messing about - just get a Sub-driver!Comment
The channel is to permit rearward travel of the shock-absorber plunger and spring after releasing the forward retaining wheel-collar.
DavidLast edited by Tugfan; 11-29-2012, 10:17 AM.Comment
Mike and I wrote the Manual. We recommend that our customers read it.
I know you have worked this all out but here is a thought about the snorkel mounting.
It has been said to leave off all the breakable parts in a working RC model.
The snorkel looks prone to getting bent and broke as it stands proud before the sail is placed over it.
What if the snorkel was fastened up into the sail instead of mounted to the hull. Then the snorkels
alignment inside the sail doesn't change and if the sail takes a bump the snorkel doesn't get bent.
"The sail is removable is afford access to the hull mounted SAS snorkel assembly,"
Scott T
Scott,
I've played with just that configuration, but settled on the hull mounted snorkel assembly.
The sail is only removed for a mission check, not at the field. So, exposure of the snorkel assembly to handling damage is minimal. What finalized the decision to mount the snorkel to the hull was that it made fast the elbow fitting within the hull that mates with the flexible induction hose that leads to the five-point manifold. Gluing the elbow to the hull insures that stress applied to it by handling of the flexible hose would not shift the induction tubes position within the tight confines of the sail -- such movement maybe causing the float to bind within the sail, leading to an induction line flooding incident.
A good observation, and I did give thought to both means of securing the snorkel assembly, Scott.
