s/d help
  • satlite440
    • Jul 2012
    • 177
    s/d help
    ok still moveing along..battery room and mission switch compleate with strain block..haveing some issues getting the electrics right..here is what i have so far..the lipo gard adf2 interface along with the lpb/ballest tank servo y harrness.if you guys need better pics or different angles let me know and i will post them as i would be gratfull for all the help i can get in the black art of s/d's i have been pouring over the caball's and gazzettes and i remeber a pic of the type vIIc snort induction line in the tower but can't seem to find it again was it in the sky periscope forward or the attack periscope to the rear?...many thanks shaneClick image for larger version
Name:	sd help 001.JPG
ID:	102035Click image for larger version
Name:	sd help 002.jpg
ID:	102036Click image for larger version
ID:	102037Click image for larger version
ID:	102038Click image for larger version
ID:	102039Click image for larger version
    I remember seeing it in the rear periscopes pedestal.
    • satlite440
      • Jul 2012
      • 177
Name:	sd help2 001.jpg
ID:	73644Click image for larger version
Name:	sd help2 002.jpg
ID:	73645Click image for larger version
Name:	sd help2 003.jpg
ID:	73646so i think i might be closer to figuring this out. so a little help from the senior captians would be great. as you can see i have the wyfly 6 and lepton 6..all of the hookups i have seen are for the 8ch receiver.. so i have it set up like this
      adf2 input to ch6 of receiver,stern plane servo to adf2 output..
      what am i missing?????
      lipogard to ch4 of receiver,input from adf2 fs side to lipogard..
      output of adf2 fs side to y harrness
      y harrness lead 1 to vent/blow servo
      y harrness lead 2 to lpb moter...
      but now ch5 is empty is that right??????
        You got it right.
        Why this gut-wrenching need to fill the receiver ch-5 port? You worried the Magic-Smoke will leak out of the receiver?
        Talk about anal-retentive!....
        • satlite440
          • Jul 2012
          • 177
          thanks dave i just want to get it right.. never done planes or subs before ,just surface boats with 3-4 channels and nothing fancy. i still consider my self a novice at r/c.. the cabal's and this forum made me want to start this and finish it.thanks for putting up with a self admited babe in the woods pestering....thanks shane...
