I learned an incredible amount from looking at pictures posted just in the last 6-7 months and I think it's very refreshing to see what someone is up to in their shop each day that they post about a project. In keeping with that idea of "Today's work" I'm going to start posting pictures of what I do in my shop when I can though as a warning, it probably won't be daily. Enjoy and if explanation is needed I'll answer the best I can.
Making stuff
Looking forward to it. I can learn stuff as well.I learned an incredible amount from looking at pictures posted just in the last 6-7 months and I think it's very refreshing to see what someone is up to in their shop each day that they post about a project. In keeping with that idea of "Today's work" I'm going to start posting pictures of what I do in my shop when I can though as a warning, it probably won't be daily. Enjoy and if explanation is needed I'll answer the best I can.Who is John Galt? -
When I got my Blueback, the bull gear in the driver had 4 teeth a little worse for wear so I had to replace it. Just so happens that I know how to make gears so I got a piece of 1” delrin and made one. Then I found out through reading on the forum not long ago that a buddy needed some of the same gears so I decided to make a few more. Anywho, here are some pictures of the process.😀 1Comment
... and your buddy is most appreciative, Louis!When I got my Blueback, the bull gear in the driver had 4 teeth a little worse for wear so I had to replace it. Just so happens that I know how to make gears so I got a piece of 1” delrin and made one. Then I found out through reading on the forum not long ago that a buddy needed some of the same gears so I decided to make a few more. Anywho, here are some pictures of the process.Who is John Galt?Comment
Lockleer1 -
I know absolutely nothing about lathes or machining but I’m quite interested in how one makes a gear. Is the cylinder with a circular object around it a cutting tool to make the grooves? And behind that is the actual gear that is being cut? How do the grooves get evenly spaced? Thank you.
TimLast edited by Timothy L; 10-21-2026, 02:22 PM.Comment
Sir, the fixture you see is a spin jig/index. Looking at the indexing plate, there are graduations on the other side divided in 10 degree increments to keep things simple for now. In order to get the teeth spaced properly, there is a pin to hold the index plate at each graduation required, in this case we’re making a 36 tooth gear so simply one cut every 10 degrees and then you have a gear stock. Which in the picture is in fact the black delrin rod you see that has a bit of fuzzy swarf on the end.Last edited by Lockleer1; 10-21-2026, 05:56 PM.Comment
