Making stuff
  • Lockleer1
    • May 2025
    • 51
    Making stuff
    I learned an incredible amount from looking at pictures posted just in the last 6-7 months and I think it's very refreshing to see what someone is up to in their shop each day that they post about a project. In keeping with that idea of "Today's work" I'm going to start posting pictures of what I do in my shop when I can though as a warning, it probably won't be daily. Enjoy and if explanation is needed I'll answer the best I can.
    • 13976
    Looking forward to it. I can learn stuff as well.
    • Lockleer1
      • May 2025
      • 51
      Driver for a 1/144 Typhoon. My first twin screw and first one I did with servos in the forward bulkhead.
      • Lockleer1
        • May 2025
        • 51
        1/144 Typhoon driver
        • Lockleer1
          • May 2025
          • 51
          1/144 Typhoon driver, more pictures
          • Lockleer1
            • May 2025
            • 51
            1/144 Typhoon driver, lots more pictures
            • Lockleer1
              • May 2025
              • 51
              1/144 Typhoon driver done! I built this for a buddy, Never has he been involved with subs so I recommended a dynamic boat first. Maybe change it to a ballast system later once I finalize my design.
              • Lockleer1
                • May 2025
                • 51
                When I got my Blueback, the bull gear in the driver had 4 teeth a little worse for wear so I had to replace it. Just so happens that I know how to make gears so I got a piece of 1” delrin and made one. Then I found out through reading on the forum not long ago that a buddy needed some of the same gears so I decided to make a few more. Anywho, here are some pictures of the process.
                  • 13976
                  ... and your buddy is most appreciative, Louis!
                  • Lockleer1
                    • May 2025
                    • 51
                    I’m extremely happy for that of course, thank you sir!
