12VDC DeWalt Power Adapter
  • Ed Kirk
    • Dec 2025
    • 34
    I am impressed with my 12 volt DeWalt drill, run time and power is great. Considering using in my RC sub, maybe in the wet side, Any opinions?
  • RCENGR
    • May 2025
    • 21
    There are circuit boards internal to those batteries. You shouldn't get them wet unless you waterproof them somehow. https://youtu.be/8eDtZX6isbI?si=BkzVN2BgJ-LXqsT2&t=377
Name:	Dewalt internal.jpg
    • Fishb0y
      • Jul 2023
      • 140
      A dive scooter manufacturer currently employs these batteries in a dry-sealed application. My older model uses a legacy proprietary battery pack, and converting to tool batteries would provide greater flexibility and ease of replacement. https://dive-xtras.com/pages/cuda-x-series
        • 2481
        Just lithium cells in a pack. Look for 18650 and 21700 cells.
          • 707
          What are the amp hours of that battery? AMPH?
          • Ed Kirk
            • Dec 2025
            • 34
            12V @2AH, I get hours of heavy use like installing self taping wood screws. I am impressed at how long it last.
            • Ed Kirk
              • Dec 2025
              • 34
              Got one, using it on my workbench for 12VDC power supply. Works great, don't think I will put it in a boat. PS - it comes with a fuse, very handy, had a speed controller with a short, no damage.
                • 1567
                It seems if you try to correct a post more than once for spelling, or whatever reason, it gets flagged. This has really gotten old.
                  • 1567
                  Delete delete
                    • 1567
                    Water can cause corrosion and damage to the internal components of the battery. My opinion? Stop asking ridiculous questions about running batteries in wet, especially batteries that weren’t meant to be wet, period. Do you really think that a drill battery was meant to run in water? There are plenty of batteries out there that will fulfill your needs, in dry conditions. The battery pack itself is a potential hazard. If submerged in water, it can short-circuit, overheat, and even explode. And I don’t give a damn what kind of experiments have been run with batteries and water, you’re always risking yourself and your boat by doing it. Just imagine you submerge your battery and water, run it for a certain amount of time, bring it out, open it up and it blows up in your face, hurting you and someone else. You really want to take that risk? If so, get yourself some extra insurance. Lastly, DeWalt drills typically use lithium-ion batteries. Screw with those, and you’re gonna get hurt.
