BEGINNERS LIST:
ALWAYS CHECK THIS FAVORITES LIST:
RUDDER HORNS
LINKAGE HORNS
TRANSMITTERS/RECEIVERS
SUBDRIVERS
MISC. ELECTRONICS
BRUSHED ESC
BRUSHLESS ESC
https://www.amazon.com/dp/B0BJZ4M18D?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_5
PUMPS
https://www.amazon.com/dp/B083173DPW?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_1
BRASS/SS RODS
AMAZON
INLINE FUSE
RG178 ANTENNA CABLE FOR 2.4GHz
LEVER WIRE CONNECTORS
WHEEL COLLARS REPLACE SUPPLIEDMETAL GRUBS WITH SS GRUBS 4/40
https://www.amazon.com/dp/B0006NAVL4?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_3&th=1
DRIVE SHAFT CONNECTORS
SS 3MM RODS FOR DRIVE SHAFT
https://www.amazon.com/Lyrlidr-Stainless-Industry-Working-Hobbies/dp/B0DCBCRB1C/ref=sr_1_3?crid=2WE49H7UIVH66&dib=eyJ2IjoiMSJ9.b0c BAgcORpMiA32HmWsLoVspfCtE2OGDhBtwkfLmYCKe6r-vJQCbyRdzuE7LHcFJDxGVeSpf3hXX5KFFEjUkYgtUyDyDTMcnk E6fWOP8EcmakKU0z7lxJ4UWVk-9DQ1ROlqOeFNglb7vrcKQ-aJBUTG58ipgA0Wn4PDzIk5Au97nxn1gQcTv2__q9T0JJUQOWh2 2dK9jomAG20kkRIOzOL4dOkSOtuLNjKjakn1nNL8.Uvo6j4EL7 FJ5RUbLdm0OYhSaIdnYwIeDF2f7oOG68cQ&dib_tag=se&keyw ords=SS%2B3MM%2BROD&qid=1766079740&sprefix=ss%2B3m m%2Brod%2Caps%2C103&sr=8-3&th=1
SS 4MM RODS FOR DRIVE SHAFT
https://www.amazon.com/uxcell-300mm-Stainless-Steel-Solid/dp/B082ZNGFZY/ref=sr_1_3?crid=2SYLPX3XO71OY&dib=eyJ2IjoiMSJ9.acJ DqRSJ_ATkTinDlFdf2GssCns8MVoMhdjbhIl9IU_-UOMCqI7wN7nj7xCvah5ZFydXKVPUYrS_MXS-yaBSLtlbwm1WHCxRAMTaujR042Y40t27zIOm97Y9fwBIPn8gBu x2_A1NtBDeiWweVSGeI8B100rP5tvWeJFiss_N3lDRLLoTyRJL mMBETCHs5L-wTubr-CWJ4CrKr0DqN-FslM8Ci8CIC9L6tloH0k-ae-s.dETxNKYxBI-SFmkyywNpT5jNN4kclPNvQfAClh9WfWc&dib_tag=se&keywor ds=SS%2B4MM%2BROD&qid=1766079748&sprefix=ss%2B4mm% 2Brod%2Caps%2C112&sr=8-3&th=1
MAGNETS
TUBING
PROPS
LIPO BALANCE CAPS:
https://www.ebay.com/itm/403758451961?mkevt=1&mkpid=0&emsid=e11400.m144671. l197929&mkcid=7&ch=osgood&euid=57f21e5ffb2f423687a 96b78e17a0b33&bu=44032538346&osub=-1%7E1&crd=20251013092442&segname=11400
AIR LINE TUBING COUPLERS? 1/8”
https://www.usplastic.com/catalog/item.aspx?itemid=34779&clickid=search
REMOTE CONTROL SWITCH
https://www.amazon.com/dp/B0B1QF8Y3Z?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_1&th=1
DOUBLE SIDED ELECTRONICS FIXING TAPE
https://www.amazon.com/dp/B07MJZ26BR?ref=ppx_yo2ov_dt_b_fed_asin_title
WATERPROOF PLUG JACKS
https://www.rc-submarine.com/rcsubguy-s-favorite-products
FOAM
PINK OR BLUE CLOSED CELL INSULATION FOAM, ADHERE WITH PERMATEX RTV
BRASS TUBES 1/16” NESTS INTO 3/32”
BRASS TUBES 3/32” NESTS INTO 1/8”
BRASS TUBES 1/8” NESTS INTO 5/32”
VIDEOS:
LINKAGE RODS ADJUSTABLE
GLUES & PAINTS
WATER TIGHT SEALS
