BEGINNERS LIST:
ALWAYS CHECK THIS FAVORITES LIST:
RUDDER HORNS
LINKAGE HORNS
TRANSMITTERS/RECEIVERS
SUBDRIVERS
MISC. ELECTRONICS
BRUSHED ESC
BRUSHLESS ESC
PUMPS
BRASS/SS RODS
AMAZON
INLINE FUSE
RG178 ANTENNA CABLE FOR 2.4GHz
LEVER WIRE CONNECTORS
WHEEL COLLARS REPLACE SUPPLIEDMETAL GRUBS WITH SS GRUBS 4/40
DRIVE SHAFT CONNECTORS
SS 3MM RODS FOR DRIVE SHAFT
SS 4MM RODS FOR DRIVE SHAFT
MAGNETS
TUBING
PROPS
LIPO BALANCE CAPS:
AIR LINE TUBING COUPLERS? 1/8”
REMOTE CONTROL SWITCH
DOUBLE SIDED ELECTRONICS FIXING TAPE
WATERPROOF PLUG JACKS
FOAM
PINK OR BLUE CLOSED CELL INSULATION FOAM, ADHERE WITH PERMATEX RTV
BRASS TUBES 1/16” NESTS INTO 3/32”
BRASS TUBES 3/32” NESTS INTO 1/8”
BRASS TUBES 1/8” NESTS INTO 5/32”
VIDEOS:
LINKAGE RODS ADJUSTABLE
GLUES & PAINTS
WATER TIGHT SEALS
