Semi-Aspirated Ballast System
    • 3631
    "See our new Sub-driver with the unique Semi-Aspirated System"
    Noticed this announcement while looking for new post on the forum but i can seem to locate a dedicated thread.
    • 3717
    I got the impression it is vapor-ware at the moment. Still under construction or a mythological device rumored to exist. LOL
      • 3631
      Don't want to preempt David about his new system Trout but it does exist. I emailed David regarding his Semi-Aspirated Ballast System or SAS after he mentioned it in Kazzer's M1 Disaster thread. He was kind enough to explain to me how it works. He even sent me some pictures of the components which I assure you will blow you away once you see them. He has already conducted some water test last week. I assumed he has already made a formal cabal report on it.
      • Slats
        • 1776
        Its promising kiddies, very promising indeed. Just be patient.
        sigpic
          • 3717
          I pray I did not come across as doubting David. He is one man I admire for his bold approach to problems and his creative solutions. I would install his device in my sub today knowing the thought he would put into it. No I do not sell David short. I got the impression it was still undeveloped and incorrectly how far along it is.
            • 13855
            "Oh, Yea of Little Faith!"
            (insert: crack of thunder; chorus singing long sustained note; rolling black clouds; and the other usual Cecil B. DeMille horse-****)
              I'm testing some ads, and this was part of it. More will be apparent as time progresses. No dedicated thread at present.
              • roedj
                • Sep 2008
                • 563
                D or M,
                OK, it's not quite ready for prime time yet but could you please tell us (me) what is meant by the term 'semi aspirated'? When I was younger I attended a few college parties and got 'semi aspirated' myself but that's probably not what's meant here.
                Dan
                  • 3717
                  Forgive me....... I want to try one out. Is there a beta program I can participate in????? I will document!
                  Tom
                  • Reckless
                    • Jan 2012
                    • 183
                    the picture of the SAS SD looks like my snorted SD ... what am I missing?
                      • 13855
                      Originally posted by roedj
                      D or M,
                      Dan
                      LOL. No .... as pleasant as that can be ... no, not that kind of semi-aspirated.
                      It's a snorkel that permits occasional equalization of the SD's interior after using its air to blow ballast while the induction intake is underwater. The trick was coming up with 'two-valve protection', in the form of a safety float-valve within the SD. That safety float-valve (now much reduced in foot-print over the initial prototype) insures if the snorkel head-valve fails open, the flooded induction line could not flood out the SD's interior.
                      I've got the mechanics of the plumbing in prototype form and am currently in the alfa-testing phase, and it's working. I'm producing some production tooling at this time, and should have beta-test articles out to a select few for beta-testing next week. If your boat is LPB equipped, you're 95% semi-aspirated ballast sub-system capable -- and your gas sub-system can remain as is, serving as an emergency back-up if you so wish.
                      I had help by a few of the Cabal Report elite on this and will credit them at the appropriate time.
                        Missing? What tricks one can play with the Engish language! "Soon to be - The SAS". Does it mean that the SD shown is soon to be something else? Will you ever find out?
                        Ha! Ha! ha!!!! Patience!!! Ha! Ha! Ha!
                          • 3631
                          As David mentioned there's the snorkel head valve and inside SD safety float valve.
                          Good news. David told that this set up can be made to fit a 2" SD so you could put one in your Type VII.
                            • 3631
                            You can now read David's report on the SAS in the Feb. 2012 edition of the Sub-Driver Gazette.
                            Lots of photos and technical description.
                              • 1620
                              I've read the article in the Gazette, done this trick with the floatvalves some decades ago with my type VIIC, i think you have to turn your system 180 degrees, so the floating body will be after the inlet.
                              In your configuration the flow of the water will press the floatingbody against the inlet, so releasing under speed will be more difficult, even worse, if you have some underpressure inside your WTC it will stick more, don't know exactly at which pressure it will stay sticked against the inlet.
                              Like you mentioned before, best way is to build a WTC testbed to see if the valve will be released with underpressure inside the WTC, just my two cents.
                              Greetings Manfred.
