RC Submarine "Open Diving Bell" Design
  • Johnny28
    • Sep 2025
    • 7
    Has anyone used the open diving bell design rather than WTC for a submarine?.
    I am in the process of starting to build one and wondered if anyone else has that could give me a few tips, rather than me reinventing the wheel.
  • Marylandradiosailor
    • Nov 2021
    • 75
    If the above diagram is on the internet could you provide a link as I can't clearly read the above diagram, thx.
      So basically the Sportsub Click image for larger version
ID:	190987 Click image for larger version
        1. You're going to need a lot of ballast weights to bring that air pocket down and keep boat upright.
        2. Electronics constantly exposed to high humidity.
        • Johnny28
          • Sep 2025
          • 7
          The Submarine (Motors, Hull, battery's etc.) weighs approximately 6 kilos. Total air volume is approximately 8 litres; I will have 2 litres of ballast. I believe that with these numbers (And some lead and Styrofoam) i should be able to achieve a neutrally buoyant sub at periscope depth.
          Good point with the humidity, will look into how to protect the controller, absorbent desiccant or something similar.
          • Johnny28
            • Sep 2025
            • 7
            Sorry it is not on the interwebs.... except here.... :-)
              Just put the water sensitive electronics like receiver, esc, pitch controller inside a watert tight container. The drive motor, servos and batteries can be in the wet
