Scratch built Typhoon advice needed
    • 2546
    #31
    So you didn't mention the tooth count of the Emaxx gear, but a quick google throws up something around 65 teeth, so along with the other stage of reduction I get around 16-17:1 overall reduction giving a free running spindle speed of around 750-800RPM. That is good about the right speed and reduction.
    You mentioned earlier the tanks were drawing a lot of current. What was the figure?
    • Mermod
      • Aug 2025
      • 30
      #32
      As is the draw kicks in a 5 amps then drops to about 3.5.
      yes the spur gear is a 66t 55mm diameter, i had the second one ready for the other tank in a box of goodies, turns out i engraved the o ring details on the tank end caps plus the date when it all went onto storage, the 3rd of July 2014 which got me thinking about the o ring grease sitting in tank, stripped it all down and it kinda feels like old glue so I'm currently cleaning everything, I wouldn't mind doing away with the small fragile gear setup and putting the spur gear straight on one of those planetery units then straight onto the traxxas pinion, any suggestions?
      Thanks again
      Phill
        • 2546
        #33
        Okay so going back over the figures I realise I made in error in the first stage of gearing, and your final ratio is taller at around 10.8:1, which would stretch the motors somewhat.
        if you wanted to use the motors I linked to, then bear in mind the output shaft will be larger than your 500 motor, so the pinion will need machining or you can order a new pinion with the right bore.
        The tanks will be slower to fill, estimate 25-30 seconds but should only draw a few watts free running, all assuming nothing is binding up.
        • Mermod
          • Aug 2025
          • 30
          #34
          I'm torn between the 540 or 385 motor versions, I have a habit of overdoing things, perhaps I should go with the smaller of the two.
            • 2546
            #35
            Either will work.
              • 2546
              #36
              BTW, if your tanks are pulling 3.5A at 12 volts- 42 watts for a free running tank, then something is definitely out of whack. An Engel tank draws about 4-5 watts free running and around 10-12 watts when compressing air behind it at around 2-3psi. This compares very favourably with pump based systems.
              O-rings will be a little higher in friction than the pneumatic cup seals Engel use, but not that much.
              • Mermod
                • Aug 2025
                • 30
                #37
                Well it's been a little while but after an unexpected trip to the other side of the country for a funeral I'm now back in the workshop, currently waiting on those plantery motors so im playing with bow plane retracts and looking at the drive motors, I did mention before that I have 2 st4010 820kv hobbyking motors but they seem a tad overpowered for the 60mm 7blade scimitar props I have, should I be looking at a slightly more sensible motor option but still with a bit in reserve for flank speed?
                Phill.
                  • 2546
                  #38
                  Gear them down around 2:1, assuming a 12v system and they’ll be fine.
