Chinese Sub Build
    • 1607
    Chinese Sub Build
    Don’t expect too much at one time. This is my first one. Trumpeter included what looks like missile tubes in the bottom hull. I don’t know what they’re for, but I’m gonna have to cut them out for the WTC. Also there’s a lot of flash to cut away on the hull halves. Click image for larger version
    • 13749
    These shots should give you some pointers, Casey:
      • 3564
      Recommended motor size?
        • 13749
        Anything that will fit the cylinder... I don't obsese over motor type, code, voltage, or family history. If it works, fine, if not, I cram a replacement in and see how that works.
          • 3564
          So no to prop diameter = motor can size.
            • 13749
            Sure... why not?
