Lithium Batteries
    • 691
    Lithium Batteries
    Lithium Batteries.
    Has the topic of using lithium Batteries in RC subs before?
    Most people I been around seem to use NIMH batteries. Lithium seems a lot more power dense. Great for RC aircraft of course. The price of Lithium batteries relative to NIMH batteries seem to be dropping too.
    They are very small and light. Ideal for RC submarines. Weight is less critical than in a RC aircraft, but that means less counter weighing too balancing the model, Are they a viable safe option? I have been scared reing about Lithium battery fires, on board commercial aircraft thermal runaways - scary. Can these batteries be sealed in waterproofed and placed in the free flood areas of a RC submarine? I am looking at a 12V 5 amph batteries.
  • gantu
    • 387
    Use this for bigger models there are also smaller types like 26650 or 18640.
    Regards Gantu
      • 964
      Fascinating! Great hint, Gantu!
      Jörg
      • CC Clarke
        • Aug 2020
        • 300
        Lithium and water don't mix - they explosively react. Under containment with water contact, it can blow apart metal tubes.
        All you need to pause and reflect here: Lithium Batteries Dropped in Water! TKOR Exploding Lithium Battery Experiment! (youtube.com)
        Be safe out there!
        • gantu
          • 387
          Here in Germany many submarine modeler us this kind of batteries with no problems. But not in the wet in the wtc.
          Regards Gantu
            • 1314
            I use LiFePo...working great.
            • type7
              • 189
              I have used Lipo batteries for years in subs and boats. They have much better power density which allows longer run time and charge quickly. Keep them in the wtc and use a good charger, you will be fine.
                • 691
                Wow. VERY Interesting batteries Gantu ! I really like the threaded connectors to link them together. Ingenius! So tempting and attractive, but if they get wet, I have a bomb in the pond or in the car or garage!
                It absolutely has to be double sealed; heat shrink and rubber gasket calking and placed n a dry dive module. It may be ultimately determined whether to use NIMH or LIPO batteries by space in the dry area which is already at a premium, so if forced to use outside in the wet area, for safety - MUST then use NIMH batteries ...:( Undecided.
                  • 13576
                  I've operated with Lithium polymer batteries in the wet -- no bag, no shrink-wrap, no goo, no sweat. Fresh water only. Your milage may vary.
                    • 691
                    Two extreme views on lithium batteries. **** IDK.
                    • type7
                      • 189
                      Running Lipos in the wet doesn't cause them to explode. Corrosion of the terminals and connections is the problem. I have never seen one a "waterproof" one stay waterproof very long.
                        • 13576
                        Bingo. That's why I don't attempt to waterproof ANY battery I stick in the water. Better to scrub the positive side of the wiring every now and then than to foster the mung. corrosion, and mold that builds up within a containment (so called) that never holds back the water, but will, over time, take on enough water to subject the enclosed battery cell cases and poles to a ****ing tropical forest of dampness and heat.
                        Get 'em wet and they'll be almost trouble free. Encase them in anything other than a proper WTC and you doom the battery pack to an early death.
                        But... what the hell do I know? Do as you please.
                          • 691
                          HUmmmmmmm Excellent illuminating discussions!
