Best way to cut acrylic glass sheet material?
    • 1336
    What's the best way to cut acrylic glass sheet material? I want to finish the U1 molds and for that I have to cut acrylic to get a plane against which I can laminate a proper edge (just like David did in the XXI molds). I tried cutting with a pad saw, but that occasionally resulted in cracks....
    • 13685
    Score and snap.
      • 1336
      Do you have to score both sides?
        • 13685
        Yes, and deeply. A tool, something like this:
          • 1336
          Thanks...I hate working with acrylic glass
            • 999
            I had good results with a good rough wood saw and water-cooling. Nothing fancy, but sharp counter-angled teeth. No fine saw blades, no grinders
              • 2513
              PMMA does vary hugely in quality. Some of it is like working with glass, others are much more forgiving. Good brands often ensure consistency.
                • 13685
                Cast acrylic good. Extruded acrylic bad.
                  • 1336
                  I have cast...that much I know
                    • 3502
                    How do you put the hook, ground or bent after heating?
                      • 13685
                      Cast is easier to heat-form and less likely to spontaneously crack. Extruded has none of these virtues.
