AI designed Ballast System
    • 3644
    Tried ChatGPT while I was doing laundry.
    Designing a pump-based vented ballast tank system for an RC submarine
    Here’s a conceptual diagram of the system: Click image for larger version
    Components:
    1. Ballast Tank (BT)
    2. Water Fill Pump (WFP)
    3. Water Empty Pump (WEP)
    4. Air Vent Valve (AVV)
    5. Non-Return Valves (NRV)
    6. Flexible Tubing (FT)
    7. Control System (CS)
    8. Power Supply (PS)
    Conceptual Diagram:
    Explanation:
    1. Ballast Tank (BT):
      • The central component that holds water to adjust buoyancy.
    2. Water Fill Pump (WFP):
      • Pumps water into the ballast tank to increase weight and submerge the submarine.
    3. Water Empty Pump (WEP):
      • Pumps water out of the ballast tank to decrease weight and make the submarine rise.
    4. Air Vent Valve (AVV):
      • Allows air to escape when the ballast tank is filling with water and lets air into the tank when emptying.
    5. Non-Return Valves (NRV):
      • Prevent backflow of water and ensure proper flow direction in the tubing.
    6. Flexible Tubing (FT):
      • Connects the pumps, valves, and ballast tank.
    7. Control System (CS):
      • Manages the operation of the pumps and valves based on remote commands.
    8. Power Supply (PS):
      • Provides power to the pumps and control system.
    System Operation:
    1. Filling the Tank:
      • The air vent valve (AVV) is opened to let air out of the ballast tank.
      • The water fill pump (WFP) activates to fill the tank with water.
      • Non-return valves (NRV) ensure water flows in the right direction.
    2. Emptying the Tank:
      • The air vent valve (AVV) is closed to trap air inside the tank.
      • The water empty pump (WEP) activates to pump water out of the tank.
      • Non-return valves (NRV) ensure proper water flow.
    This design allows precise control over the submarine's buoyancy and depth. Adjustments to the components and control system may be needed based on specific requirements and testing.
    • 3644
    ChatGPT designed ballast tank using wind shield washer pump:
    Using a windshield washer pump for an RC submarine ballast tank system is a practical and cost-effective solution. Windshield washer pumps are compact, relatively powerful, and waterproof, making them suitable for this application. Here’s a detailed guide on how to design and implement a ballast tank system using windshield washer pumps.
    Components Needed:
    Windshield Washer Pumps:
    Two pumps (one for filling and one for emptying the ballast tank).
    Ballast Tank:
    A watertight container that can be filled and emptied of water.
    Valves:
    Non-return valves to prevent backflow of water.
    Tubing:
    Flexible tubing to connect the pumps to the ballast tank and the external environment.
    Control System:
    Remote control unit.
    Microcontroller (e.g., Arduino) to manage the pump operations.
    Power Supply:
    Batteries compatible with the power requirements of the pumps and control system.
    Steps to Design and Build the System:
    Ballast Tank Construction:
    Ensure the ballast tank is watertight and has proper inlets and outlets for water flow.
    Secure the ballast tank inside the submarine hull.
    Pump Installation:
    Install the windshield washer pumps inside the hull.
    Connect one pump to fill the ballast tank and the other pump to empty it.
    Valve Integration:
    Install non-return valves in the tubing to prevent backflow.
    Ensure the valves are oriented correctly to allow water to flow in the desired direction.
    Tubing Setup:
    Connect the inlet of the fill pump to the external water source and the outlet to the ballast tank.
    Connect the inlet of the empty pump to the ballast tank and the outlet to the external environment.
    Control System Setup:
    Connect the pumps to a microcontroller.
    Program the microcontroller to control the pumps based on signals from the remote control unit.
    Power Supply Configuration:
    Connect the pumps and control system to a suitable battery pack.
    Ensure all electrical connections are secure and waterproof.
    Testing and Calibration:
    Test the system in a controlled environment, like a pool.
    Calibrate the pumps to ensure the submarine can achieve neutral buoyancy and control depth accurately.
    Final Assembly:
    Once tested and calibrated, assemble the submarine fully.
    Ensure all components are secure and watertight.
    Operational Testing:
    Test the submarine in open water to ensure it functions correctly.
    Make adjustments as necessary for optimal performance.
    Example Code for Arduino (Basic):
    cpp
    Copy code
    #define FILL_PUMP_PIN 9
    #define EMPTY_PUMP_PIN 10
    void setup() {
    pinMode(FILL_PUMP_PIN, OUTPUT);
    pinMode(EMPTY_PUMP_PIN, OUTPUT);
    Serial.begin(9600);
    void loop() {
    if (Serial.available() > 0) {
    char command = Serial.read();
    if (command == 'f') {
    // Fill ballast tank
    digitalWrite(FILL_PUMP_PIN, HIGH); // Turn on fill pump
    delay(10000); // Adjust time as needed to fill the tank
    digitalWrite(FILL_PUMP_PIN, LOW); // Turn off fill pump
    } else if (command == 'e') {
    // Empty ballast tank
    digitalWrite(EMPTY_PUMP_PIN, HIGH); // Turn on empty pump
    delay(10000); // Adjust time as needed to empty the tank
    digitalWrite(EMPTY_PUMP_PIN, LOW); // Turn off empty pump
    } else {
    // Stop all pumps
    This code provides basic control over the fill and empty pumps via serial commands. Adjust the delay durations based on the actual time required to fill and empty the ballast tank.
    Additional Tips:
    Waterproofing: Ensure all electrical connections and the microcontroller are properly waterproofed to avoid damage.
    Balancing: Position the ballast tank centrally and adjust the submarine's internal components to maintain balance.
    Remote Control Integration: Depending on your remote control setup, you might need additional circuitry or code modifications to integrate with the microcontroller.
    By following these steps and carefully testing the system, you can create an effective ballast system for your RC submarine using windshield washer pumps.
      • 3644
      Chatgpt designed pump based ballast system for RC submarine:
      Designing a pump-based ballast system for an RC submarine involves a few key components and steps to ensure proper functionality and control. Here's a basic outline to help you get started:
      Components Needed:
      Submarine Hull:
      Design or obtain a hull suitable for your RC submarine.
      Ballast Tanks:
      At least two ballast tanks (fore and aft) for balanced buoyancy control.
      Watertight and durable materials.
      Water Pumps:
      Small, submersible pumps to fill and empty the ballast tanks.
      Typically, one pump per tank.
      Control System:
      Remote control unit to operate the pumps.
      Microcontroller (e.g., Arduino) to manage pump operations.
      Valves:
      Non-return valves to prevent water from flowing back into the pump.
      Power Supply:
      Pressure Sensors (Optional):
      To monitor and control the water level in the ballast tanks accurately.
      Steps to Design the System:
      Hull Design:
      Ensure the hull is watertight and has space for the internal components.
      Consider using a modular design for easy maintenance and component replacement.
      Ballast Tank Placement:
      Install ballast tanks at the fore and aft ends of the submarine to maintain balance.
      Secure tanks firmly within the hull.
      Pump Installation:
      Install submersible pumps inside the hull, with inlets and outlets connected to the ballast tanks.
      Ensure pumps are properly sealed and waterproof.
      Connect the pumps to a microcontroller (e.g., Arduino).
      Valve Integration:
      Install non-return valves in the water lines to prevent backflow.
      Ensure valves are oriented correctly to allow water to flow in the desired direction only.
      Optional: Pressure Sensor Integration:
      Install pressure sensors in the ballast tanks to monitor water levels.
      Program the microcontroller to use sensor data for precise ballast control.
      Calibrate the pumps and control system to ensure the submarine can achieve neutral buoyancy and control depth accurately.
      Final Assembly:
      cpp
      Copy code
      #include <Servo.h>
      Servo pump1;
      Servo pump2;
      int pump1Pin = 9;
      int pump2Pin = 10;
      void setup() {
      pump1.attach(pump1Pin);
      pump2.attach(pump2Pin);
      Serial.begin(9600);
      void loop() {
      // Fill ballast tanks
      pump1.write(180);
      pump2.write(180);
      // Empty ballast tanks
      pump1.write(0);
      pump2.write(0);
      } else {
      // Stop pumps
      pump1.write(90);
      pump2.write(90);
      This is a simplified example to get you started. Depending on your exact requirements and components, you may need to expand and modify the code accordingly.
      Designing an RC submarine with a pump-based ballast system can be complex, but with careful planning and testing, you can achieve a functional and controllable model.
      Making vented ballast tank for rc sub:
      Creating a vented ballast tank for an RC submarine involves designing a system where the tank can be flooded with water to increase the submarine's weight (and thus its depth) and then vented to release the water and decrease the weight to rise back up. Here’s how you can design and build such a system:
      Components Needed:
      Ballast Tank:
      Watertight container that can be filled and emptied of water.
      Typically made of durable plastic or metal.
      Water Pumps:
      Small submersible pumps to fill and empty the ballast tanks.
      Air Pump:
      Small pump to vent air out of the ballast tank.
      Valves:
      Air vent valves to allow air to escape when the tank is being flooded and to let air in when the tank is being emptied.
      Control System:
      Remote control unit to operate the pumps and valves.
      Microcontroller (e.g., Arduino) to manage pump and valve operations.
      Power Supply:
      Ensure the ballast tank is watertight.
      Install water inlets and outlets, as well as air vent openings.
      Place the tank inside the submarine hull, ensuring it's securely mounted.
      Pump Installation:
      Install water pumps inside the hull with inlets connected to the ballast tank and outlets connected to the outside of the hull.
      Install the air pump with its inlet connected to the air vent opening of the ballast tank.
      Valve Integration:
      Install air vent valves to control the release and intake of air.
      Connect the pumps and valves to a microcontroller.
      Program the microcontroller to control the pumps and valves based on signals from the remote control unit.
      Final Assembly:
      cpp
      Copy code
      #include <Servo.h>
      Servo waterPumpFill;
      Servo waterPumpEmpty;
      Servo airPump;
      Servo airVentValve;
      int waterPumpFillPin = 9;
      int waterPumpEmptyPin = 10;
      int airPumpPin = 11;
      int airVentValvePin = 12;
      void setup() {
      waterPumpFill.attach(waterPumpFillPin);
      waterPumpEmpty.attach(waterPumpEmptyPin);
      airPump.attach(airPumpPin);
      airVentValve.attach(airVentValvePin);
      Serial.begin(9600);
      void loop() {
      airVentValve.write(180); // Open air vent valve
      waterPumpFill.write(180); // Start filling with water
      waterPumpFill.write(90); // Stop water pump
      airVentValve.write(90); // Close air vent valve
      airPump.write(180); // Start air pump
      waterPumpEmpty.write(180); // Start emptying water
      waterPumpEmpty.write(90); // Stop water pump
      airPump.write(90); // Stop air pump
      } else {
      // Stop all pumps and valves
      airPump.write(90);
      This code provides a basic control scheme for filling and emptying the ballast tank using water and air pumps and valves. Depending on your exact requirements and components, you may need to expand and modify the code accordingly.
      By carefully designing and testing your vented ballast system, you can achieve precise control over the buoyancy and depth of your RC submarine.
        • 13908
        Remember what became of the Bellerophon party...
          • Oct 2017
          • 1034
          Use your own brain. Skip Skynet's fellow.
          Make a practical design. This is overkill.
            • 3644
            just wanted to it out after I saw this
            • bwi 971
              • Jan 2015
              • 940
              According AI this is the laundry o/b a WWII sub.
              I think this would have done the job to get my boiler suit clean after cleaning the scavenging of the ME.
              Click image for larger version  Name:	2024-07-24 00_49_17-Ontwerp zonder titel - Instagram-bericht.jpg Views:	0 Size:	76.6 KB ID:	181568
              "Samuel Smiles"
