Oberon Class Capstan Availability?
  • wlambing
    • Nov 2020
    • 383
    Anyone know of a source for a 1:48 scale Oberon capstan warping drum, either 3D, or cast urethane, that I could buy? The open stave design of the thing and lack of dimensional info is keeping me from making one myself. It was not retractable, so it should be in place on deck for a proper looking vessel. Thanks!!
  • Oberon
    • Jul 2024
    • 10
    The capstan winding barrel shows as about 14mm by 10mm on Ted Scriven's 1/48 scale Oberon plans.
    • Oberon
      • Jul 2024
      • 10
      better pic
      • Oberon
        • Jul 2024
        • 10
        Very hard to see the capstan because its quite small
        Click image for larger version  Name:	oberon1-17.jpg Views:	0 Size:	106.9 KB ID:	181267
        Sometimes hard to see because its quite small.Click image for larger version  Name:	oberon1-15.jpg Views:	0 Size:	101.5 KB ID:	181268
        Click image for larger version  Name:	oberon1-16.jpg Views:	0 Size:	101.1 KB ID:	181269
          • 2503
          Does it look a bit like this?
            • 3468
ID:	181276 ........... Click image for larger version  Name:	10-bow.jpg Views:	6 Size:	71.3 KB ID:	181273
              • 2503
              The first drawing was clearly very simplified. The part is clearly more detailed but would really need some better pics to produce something that wasn't at best stand-off scale.
                • 13628
                Don't let AMBS be the enemy of a completed project.
                (Advanced Model Building Syndrome).
                It's a ****ing capstan -- something you can turn on a Dremel moto-tool. Don't obsess on the damned thing. Stick a pin in it and move on!
                • wlambing
                  • Nov 2020
                  • 383
                  Thanks, folks! I'll do something that will work, just fine! :)
