Spanish S-80 Class Submarine
    • 1821
    Starting a new build!
    Click image for larger version  Name:	S-80 CLASS 2.jpg Views:	0 Size:	51.2 KB ID:	178021
    This is the Spanish S-80 Class submarine that went into design and production between 2003 and 2010. The scale that I will be building it at is a little larger than 1:120 scale.
    It will work out to approximately 24" to 26" in length, and roughly a 3" beam. I will be building it (3D Printed) from PLA with a 100% infill. I will incorporate a 2" scratch built WTC.
    "Firemen can stand the heat."
    • 1821
    I have finished printing out the bottom sections of the hull.
    Click image for larger version  Name:	S-80 CLASS 3.jpg Views:	8 Size:	60.4 KB ID:	178023
    I also have the bow and the two stern sections completed as well.
    Click image for larger version  Name:	S-80 CLASS 4.jpg Views:	9 Size:	66.2 KB ID:	178024 Click image for larger version  Name:	S-80 CLASS 5.jpg Views:	9 Size:	59.2 KB ID:	178025
    I have two other submarines in the building stages as well, so I will be working on the S-80 along with the (Seaview and the Stickleback)
    (Just can't get enough building)
      • 1821
      Tonight I am starting the hull glue up on my S-80.
Name:	S-80 CLASS 6.jpg
      I have just a few more accessory parts yet to print out (rudders, dive planes, and some sail antenna) and I will be able to move this boat into production phase.
        • 1821
        Made a little more progress on the S-80 hull.
Name:	S-80 CLASS 8.jpg
ID:	178093 Click image for larger version
Name:	S-80 CLASS 7.jpg
        I have the lower and upper hull sections glue together. I went a head and tapped the upper hull to the lower to get an idea as to how well they are going to come together.
        I am going to have to fabricate some tabs for both sections in order to get a good positive fit.
          • 1821
          After our Dive Tribe get together today (and David M.) great presentation on vacuforming, I went back to work on my S-80.
Name:	S-80 CLASS 9.jpg
          I went into Tinkercad and designed and built the joint supports for the hull.
Name:	S-80 CLASS 10.jpg
          I am also going to fabricate supports for the top hull sections.
            • 2775
            Ballast system or surface runner?
              • 1821
              Romel,
              At this point not sure. 50/50. but might be a good dynamic diver!?
                • 2775
                Looks like you still got plenty of space in the WTC for a gear/peristaltic pump ballast system.
