3D Printed USOS Seaview project
    Casey,
    The only monster I have created right now is the Seaview! Still at a loss as to where I am going to find room for it when finished. I can always stand it up vertically, I guess?
    "Firemen can stand the heat."
    Come on, you old fart!... you were once a kid. We would hang our models off the ceiling.
    Originally posted by Das Boot
    Any monsters you could 3D?
    Casey,
    This photo is for "Casey!"
    AS you can see I am making headway on the hull construction. test fitting parts to be sure they fit properly before you glue it up.
    It's about 1:30 AM in the morning, and I am working on the Seaview Command Deck.
    I have approximately 30 more parts to print out to finish up the command deck parts.
    As I am building up the hull of the Seaview, I am also starting to print out the accessories.
    The photo above shows the beginning of the Command Deck parts. As I have stated at the beginning of this build, my Seaview is at 65% and not 100% size.
    As small as these parts are, I have got to say that my little FlashForge printer is doing an exceptionally great job at printing them. As good as or might be even better that a Resin printer could do! And with mush less hassle and mess, and not to mention the chemicals involved.
    At this point I have all the hull sections printed out.
    I am going to start the actual glue up form the bow of the boat to the stern. There will be some light seam filling and sanding along the way, and I am going to do that as I put each section together..
    Casey,
    Looks like a perfect size for your desk area! Who makes the kit?
    Moebius kits.
    Originally posted by Alucard
    3D printing is amazing, everything looks good, is it hard to program what you are printing, I know you buy the files, but do you then just scan them, or do you have type them in?
    Alan,
    When you purchase the files (STL is what I use) I download the files in the STL format. From there I download the file to my printer using Simol
    This photo shows my Dremel build plate. I am using Simplify 3D as my slicer. This is before the download to the plate has been done.
    In this photo the part has been downloaded to the build plate.
    This photo shows the part with supports that are required during the print process. This is also where you set up your part sizing, the infill you want to use, and any other settings you might want to use.
    This the part that has been prepared for printing. From this point you down load this frame onto a SD card and the SD card goes to the printer for the printing process.
    The photos I have listed above is just a short rundown on the process that takes place to print a part from the STL files. There is more to it, but this gives you a somewhat idea as to the process. Hope this has helped explain the printing process!
    Do the files include the water intakes opening under the nacelles?
    As David mentioned even if the intake grills are molded open they cannot supply sufficient water for the pumpjets. Click image for larger version Name:	seaview 3.jpg Views:	0 Size:	91.2 KB ID:	177179
    Romel,
    Here are a couple of photos that show the intakes on the nacelles on the Seaview that I am building.
    Click image for larger version  Name:	SEAVIEW 32.jpg Views:	0 Size:	40.4 KB ID:	177182
    Click image for larger version  Name:	SEAVIEW 33.jpg Views:	0 Size:	41.1 KB ID:	177183
    Hope these help answer your question.
  • Alucard
    Beautiful!
    This 3D stuff is amazing.
    When putting the Seaview parts together and you want to use the "guide Pin Holes" Rather than using the old brass rods as pins, I might suggest using 2.85mm PLA for the pins. I had a lot of this size PLA leftover from my Robot build, so I am putting it to good use.
    Click image for larger version  Name:	SEAVIEW 31.jpg Views:	0 Size:	58.7 KB ID:	177166
    I just bored out the existing pin holes to 1/64" and the 2.85mm PLA filament fits perfect.
    Click image for larger version  Name:	SEAVIEW 30.jpg Views:	0 Size:	45.3 KB ID:	177167And in my case the holes line up perfect. Just insert a 3/8" to 1/2" piece of filament to one side of the part and a touch of CA, then apply your CA to the other part and put it together. Your piece is lined up perfect and with some additional strength that the matching material pin will give to the joint. I intend to use this process through out the entire hull construction.
