Good choice on your ESC!
I have used it on all my brushless motor propulsion systems on my WTC!
"Firemen can stand the heat."
Planetary Gear Box's
Two brushless ESCs from Amazon about $25 each running at 6v with 15,000 mAh nimh battery. I later switch the ESCs to two Mtroniks G2 Hydra50 ESCs. Way, way overkill as thats 100amp together. I did it because I said what the hell. I may bump to 20,000 mAh of power, again why not.
This was the ESC I bought from amazon. Bidirectional 40A Brushless ESC
You just need a BLHELI32 ESC. That will run a brushless motor down to the point where you count the revs. Sensorless brushless esc's have come on a long way in the last few years. The very best smooth running is achieved with motors with as many poles as you can fit in the footprint, but 14 poles is sufficient for good smooth running.Last edited by Subculture; 04-27-2023, 12:04 PM.Leave a comment:
Nice....
I will try to make a recording of the speed of the props from 1% to 100%. But even at Subfest the props were able to move very slow to fast in a smooth way. You can see the props moving smooth and slow in the water in this video with those motors.
What onboard voltage to the ESC? SLA 6V, 12V, 2s Lipo, 3s Lipo?? Need to correspond that 500KV with the voltage range she's seeing.
I'm a big fan of Engel components.Leave a comment:
This is an oldie, but used a lot in older subs.......
Will it soft start and rotate (at 1-2 click throttle) at such a speed you see the individual blades? Or does it jump right off with no low end?Leave a comment:
On my Engel Type IX, it came with a brushed motor geared setup. But we didnt like the geared system and went with two robbe 500kv brushless motors. The torq at low speed is great and it moves nice with no gearbox.
Another source for planetary and offset gearbox's:
All features: dual ball bearings some include prop adapter sturdy metal construction some include multiple pinions motor sold separately some include prop adapter sturdy metal construction some include multiple pinions motor sold separatelyManual Part No. Gear Ratio Pinion Mounting Spacing Wt oz Shaft Dia Applications
JasonLeave a comment:
The set-up you have looks absolutely fine. A planetary gearbox is useful if space is tight.
Any gear noise will be marginal from a single gear stage and much lower when running in the wet.Leave a comment:
A free script called GF Gear Generator allows for creating all kinds of custom gears in Fusion 360 and yes there are quieter gears than plain spur gears. I may give that a try but I need to run it as is first to see if another gear type will be an improvement. It should be easy enough to swap out.Leave a comment:
Yes it will be somewhat noisy but we are not exactly trying to evade an enemy here.Leave a comment:
