Planetary Gear Box's
  • QuarterMaster
    • Sep 2015
    • 1233
    ALCON,
    At that last Dive Tribe meeting there was discussion regarding gear reduction to help with poor low end performance with respect to Brushless motors.
    IE: 1​7k No Load RPM @ WOT Motor output reduced 3.8:1 now outputs 4473 RPM WOT/NL on the output shaft. The throttle range is greatly reduced assisting with that "stutter" experienced at throttle start.
    I found these in the past. Though made for brush Speed 400/480/500/600 Motors, they can be adapted to brushless with a little effort.
    MP Jet​
    Anyone out here have any other resources or know of vendors for Inline Planetary Gearboxes for brushless motors?
    v/r "Sub" Ed
    • 821
    Thanks for the good info. Ed. This is what I did on my Thresher. Motor/ESC is the Mtroniks G2 Hydra 50. 1400Kv so at 12 Vdc looking at roughly 15,000 rpms under load WOT. It was direct drive. Modified now with a spur gear (Axial p/n AX1232075) 60T/32P, pinion 15T/0.8 metric pitch which is equivalent to 32P. 4:1 ratio so turning around 3750 rpm WOT under load. Designed and 3D printed the spur gear center hub, drive shaft front support, servo mounts and ESC/cap bracket to replace the integrated part that the motor mount secured to. Spur gear center hub rides on a 10mm brass bushing I machined on my lathe that secures an M4 x 10mm set screw against the drive shaft so the set screw is long enough to extend into the 3D printed hub preventing it from rotating. The motor mount was from my original design and just so happened to fit with a thin shim under it. One minor benefit is that the motor is lower in the hull. Going to give it a try like this. May be a bit unconventional but I like to try new things. To use one of your phrases, "easy peasy lemon squeezy".
    Click image for larger version  Name:	20230423_185705_copy_2016x1134.jpg Views:	0 Size:	69.2 KB ID:	170735
    Click image for larger version  Name:	20230423_185728_copy_2016x1134.jpg Views:	0 Size:	68.8 KB ID:	170736
    • QuarterMaster
      • Sep 2015
      • 1233
      I ran transmissions in the wet since Dave Merriman's WTC3.5 I got back in the day. Works like a charm other than the "Non-Silent" drive due to the water hammering with the gears meshing. Right Dave? lol!
      You don't need to see your boat coming by submerged, you'll hear it!
      I've done as high as 9:1 to get that slow speed, close by maneuvering and to avoid "jump starts". Broken many a dogbone back in the day.
      I know use the "Go Fast Boat" Shock absorber on all my large boats. I can slam into reverse on my 3-3/4" prop without fear of transmission breaking.
      Here is one on my ALFA which sports a 630KV, 534W rated "Quantum" Outrunner. I really had to dial down the endpoints due to inability to control the model (porpoising) above 50% throttle. The motor output shaft and screw shaft are only connected via 3/8"OD 1/8" thick o-rings.
      Conquest is easy, control is not
      Kirk, J.T. ST:TOS
      I am toying with using one of those very same MP Jet gearbox's downstream in it's own WTC (to eliminate water hammers). Maybe a good weekend project.
      v/r "Sub" Ed
        • 821
        Yes it will be somewhat noisy but we are not exactly trying to evade an enemy here.
          • 2476
          Planetary gearboxes
          Also you can 3d print gears in herringbone pattern which are nice and quiet amd stronger than straight cut. Some designs on thingiverse used for gearing steppers etc. which could be adapted or grow your own using Fusion 360 gear generator.
            • 821
            Planetary gearboxes
            A free script called GF Gear Generator allows for creating all kinds of custom gears in Fusion 360 and yes there are quieter gears than plain spur gears. I may give that a try but I need to run it as is first to see if another gear type will be an improvement. It should be easy enough to swap out.
              • 2476
              The set-up you have looks absolutely fine. A planetary gearbox is useful if space is tight.
              Any gear noise will be marginal from a single gear stage and much lower when running in the wet.
                • 13597
                Running gear. A look back:
                • QuarterMaster
                  • Sep 2015
                  • 1233
                  True dat, lived with it for many years. That cylinder lived almost 15 years.
                  Of course there's the occasional query, "Ed' what's up with your reactor plant? Sounds Russian...."
                  v/r "Sub" Ed
                  • Schmitty1944
                    • Mar 2021
                    • 136
                    Another source for planetary and offset gearbox's:
                    All features: dual ball bearings some include prop adapter sturdy metal construction some include multiple pinions motor sold separately some include prop adapter sturdy metal construction some include multiple pinions motor sold separatelyManual Part No. Gear Ratio Pinion Mounting Spacing Wt oz Shaft Dia Applications
                    Jason
                    • Sinksalot
                      • Mar 2020
                      • 362
                      On my Engel Type IX, it came with a brushed motor geared setup. But we didnt like the geared system and went with two robbe 500kv brushless motors. The torq at low speed is great and it moves nice with no gearbox.
Name:	robbe motor.jpg
                      • QuarterMaster
                        • Sep 2015
                        • 1233
                        Will it soft start and rotate (at 1-2 click throttle) at such a speed you see the individual blades? Or does it jump right off with no low end?
                        v/r "Sub" Ed
                          • 3667
                          This is an oldie, but used a lot in older subs.......
                          • Sinksalot
                            • Mar 2020
                            • 362
                            I will try to make a recording of the speed of the props from 1% to 100%. But even at Subfest the props were able to move very slow to fast in a smooth way. You can see the props moving smooth and slow in the water in this video with those motors.
                            • QuarterMaster
                              • Sep 2015
                              • 1233
                              Nice....
                              What onboard voltage to the ESC? SLA 6V, 12V, 2s Lipo, 3s Lipo?? Need to correspond that 500KV with the voltage range she's seeing.
                              I'm a big fan of Engel components.
                              v/r "Sub" Ed
