ICTINCO ll Submarine Build
    Thanks Romel,
    WOW! Mine sure won't be the caliber of this one! All out of wood, that took some time!
    1/10 scale model of the Icteneo II made by a Spanish modeler Pedro Gomez. Unique thing about the boat is the power plant. It uses a model steam engine that used CO2 as the driving gas. Runtime was about 21 minutes per bottle. Drawback is you need to lug around big heavy CO2 bottles.
    The files for this build are all STL and in order to up the scale the build I will need to increase the original file size. This model is originally a static model with exposed internal components. There will be some changes made to the original files to fabricate a full size hull to build the RC version. I will be using my Dremel Digilab 40 and using Dremel white PLA for the builds!
Name:	ICTINCO ll 2.jpg
Name:	ICTINCO ll 3.jpg
    My plan is to not only to build an RC version of this boat, but also to build the original cut away model with the internal components. This boat has over 300 parts for the model build itself, but I feel it would complement the RC version which I am also building! I am really looking forward to this challenging sequence of builds.
    started a topic ICTINCO ll Submarine Build
    This will be a 3D printed build of the 1867 steam powered Ixtenco submarine!
    Click image for larger version  Name:	ICTINCO ll 1.jpg Views:	24 Size:	68.7 KB ID:	166869
    This will be a functioning in the water submarine (not steam powered) but with a WTC.
    XXXX "SPECIAL NOTE" XXXX I MISS SPELLED THE NAME OF THIS BOAT "ICTINCO" IT SHOULD BE ICTINEO!! "SORRY"
