RC plane for my Japanese 1/48 scale I-19 submarine
  • Sinksalot
    • Mar 2020
    • 362
    As many of you know I own a large ass 1/48 Japanese I-19 submarine 7 1/2 feet long. The sub launch planes off its deck during WW 2. I was able to find a small RC Japanese Zero in China, Plane is tiny with only a 300mm wingspan. Is it a perfect looking Zero, no, but its close enough for what I want it to do. To take off my sub and fly. I will update this when I get it from China, hopefully it will work out
  • Sam Victory
    • Sep 2021
    • 391
    There is a master of building rc mini planes on Youtube, named Martin Newell. He also shared some PDF information, hope it can help you.
    https://www.dropbox.com/s/owc2mq52z0...art_1.pdf?dl=0
    https://www.dropbox.com/s/s3w265wpt7...art_2.pdf?dl=0
    I had this crazy idea of having a plane take off on a submarine, and there are a lot of factors to take into account when the submarine is running, like instability. So it might be a good idea to let the plane take off using pneumatic ejection, and the huge thrust from the compressed air could help the plane get the desired speed. We can fix a small copper sleeve on the launcher, sealed at one end. The open end could be inserted into a piston (with a little hole to let gas out) , and when compressed gas is ejected from the piston's hole , the launcher could be launched along with the aircraft. Of course, you want the launcher to stop at the bow, which might be another problem.
    V
    The launcher (from I-400) :
    Click image for larger version  Name:	202011221849436ee.jpg Views:	0 Size:	74.5 KB ID:	163004
    Launching mechanism, you may need a poppet valve connect to the piston so as to release some gas at the moment.
    Click image for larger version  Name:	43761d17a8ac61e9cf42678ec928095.jpg Views:	0 Size:	61.2 KB ID:	163005
      • 1570
      Didn’t these planes have pontoons, and were set into the water by a davit?
        • 3670
        I believe launched from the deck and picked up out of the water by davit.
        • Sam Victory
          • Sep 2021
          • 391
Name:	2021-12-03 155434(55).jpg
Name:	2021-12-03 155434(23).jpg
ID:	163019Click image for larger version
ID:	163020Click image for larger version
ID:	163022Click image for larger version
          • Sinksalot
            • Mar 2020
            • 362
            The plane hardly has any weight to it. So it can take off in like 5 inch of space. This first plane will be alittle bigger then is should be. If this does work, I will get someone to make a perfect scale RC plane for me. But the Sub does have the room.
              • 1570
              Dumb question. Was the plane assembled then flown?
              • Sam Victory
                • Sep 2021
                • 391
                Yeah...
                V
                  • 3479
                  Yokosuka E14Y Navy Type 0 Submarine-borne Reconnaissance Seaplane codenamed 'Glen' was a tiny low wing monoplane reconnaissance aircraft carried onboard IJN subs.
                  The floats, support struts and the wings could all be removed for storage in the tiny hangar.
                  • Schmitty1944
                    • Mar 2021
                    • 136
                    Very cool idea. Definitely keep it simple. The plane should be extremely light weight, probably with throttle and rudder only and magnetic actuator rather than any servos. The scale wingspan of the Yokosuka E14Y is only 9" so it needs to be really light and simple to have any chance of working. Let us know how this goes, I would love to see it working!!
                    Jason
                    • Sam Victory
                      • Sep 2021
                      • 391
                      Ensuring that the aircraft is light enough is the first requirement, the second is the stability of the submarine, whether stationary or in motion. Finally there is an instantaneous large enough thrust acting on the aircraft. Ideally all three conditions are met before takeoff.
                      V
                        • 3479
                        Simple rubber band catapult B-)
                          • 3479
                            • 3479
                            • Sinksalot
                              • Mar 2020
                              • 362
                              Here is a picture of the little plane I bought. It weights 33grams.
