Hms holland 1 build
    This will be my final selection for the Holland 1 as to color and design.
Name:	HMS HOLLAN 140.jpg
    The HMS Holland 1 is nearing completion!
Name:	HMS HOLLAND 141.jpg
ID:	166032Click image for larger version
Name:	HMS HOLLAND 140.jpg
Name:	HMS HOLLAND 139.jpg
ID:	166035Click image for larger version
Name:	HMS HOLLAND 137.jpg
Name:	HMS HOLLAND 136.jpg
ID:	166037Click image for larger version
Name:	HMS HOLLAND 135.jpg
    The interior of the boat is sealed, and the exterior has two coats of primer and has been sanded in-between each coat! I still have not come up with what my final hull colors will be from the three that I have in mind. This boat is very near total completion, and now I can put all my time on the SM UC 5 U-Boat build.
    I am also going to put my printer to work on another boat, just not sure which one yet!
    Thank you, Steve,
    Ita has been one of the most challenging boats I have ever built! But it has been the best performing boat in the swimming pool! With the enlarged rudder I can now do a full 360 turn in my pool, and that makes it a joy to run.
    Ounce I have all the finish work is completed; I will be sure to have my wife take a video of it running all out in the pool!
    The HMS Holland 1 build is complete! The hull with all the accessories, and the WTC complete and functioning!
Name:	HMS HOLLAND 134.jpg
    Next comes the finishing work. I will be using an auto body grey primer 2 coats with sanding between coats and then the final hull colors, and then the final touch up finishing on the accessories!
    Looks really good Rob.
    Andreas,
    The photo of 2D plan of the HMS Holland 1 looks like it could work for you for your upcoming 3D model build! If you decide to build the model, I hope that you do a build blog. I for one would be looking forward to it. You are the master at this concept, and the HMS Holland 1 is such a distinctive looking boat! Thanks for posting up the photo! :-))
  • DrSchmidt
    Working....
    As I stated before after I had my first run in the water, I may be enlarging the upper and lower rudder!
Name:	HMS HOLLAND 133.jpg
    I 3D printed two new larger rudders and I did have to cut off a little excess so they would fit. No problem!
Name:	HMS HOLLAND 132.jpg
    The old rudder is on the right in the photo. The two new rudders are 5/16" wider than the old ones.
    I think this new rudder system will give me much better turning ability in my pool! :-))
    Thanks allt, but I don't need a 3D mdel. That I can do myself. I'm just looking fr god 2D plans.....
    Sorry Andreas, I misunderstood what you said, but I will look around and try to find 2D plans...
  • DrSchmidt
    Does actually someone have good plans of the HMS Holland? Would be a nice little "cut away" display project.....
    Andreas,
    In all my travels through the internet about the HMS Holland I have not seen any7 "cut aways" of the Holland. I have not been to Thinaverse or CGtrader. I got my STL files for my Holland build from CGtrader, but I did not notice any "cut aways"!
    I will start doing some more research and see if I might find one. I got to say with your wonderful skills as a modeler, the HMS Holland would be a show case model for sure!!
  • gantu
    Hi i do have a 3d file.
  • DrSchmidt
    Thanks allot. I already found the PDF and started importing it into my CAD program. Could work....
  • jphatton
    A general arrangement plan of Holland 1-5 is in the online copy of BR3034 publication on early British submarines in plate 1;
    Also John Lamberts plan which appears to be based on the above general arrangement drawing is included in the Holland 5 wreck divers guide leaflet. The embedded plan in the PDF is reasonably high resolution if you enlarge the view of the PDF file.
  • DrSchmidt
