New info on surcouf
    New info on surcouf
    When I say new info or new pics , I mean new to me. Follow along with me as I explore these things and share it with you. Some of it you probably already know but just humur me(just smile and nod). Ive already posted these pics of the Surcouf on this forum before but I came across some new info that id like to share. Perhaps you can help me solve a mystery and then ill be able to sleep once again. Notice these pictures:Click image for larger version
Name:	surcoff on left.jpg
ID:	100982Click image for larger version
ID:	100983Click image for larger version
    I was wondering why the Surcouf was moored alongside the HMS Parthian during Wartime. Well the story goes that this picture was taken at Plymouth. The British Govt. did not want the French ships to fall into German hands and the crew of the Surcouf were not sure what to do as part of the crew wanted to fight against the Germans and the other half wanted to be loyal to the Vichy French Govt. The Captain of the Thames and the Rorqual along with Officers, Ratings and Royal Marines boarded the Surcouf and confronted its Captain and Men about their Loyalties. A gun and bayonet exchange ensued and both British Captains and two ratings were killed, along with a equal number of the French. After that almost all the French were replaced with a British crew as the Surcouf was added to the British Fleet. So she was sent on several missions and she was very unpopular with her British crew. Finally she was sent to transit the Panama canal and be posted in and around Tahiti. She never made it as she collided with a American Transport and sank with all hands.
      Here is where you come in. The info on the Surcouf says that she was armed with two external rotating multi barrel torpedo launchers that were designed to handle one 21" and two 17" torpedos. I cant figure out where they are so im going to post all the pictures of it that I have that might help and maybe someone can pick it out.Click image for larger version
ID:	62408Click image for larger version
      You can see the Surcouf in the background.
ID:	62411Click image for larger version
      A floatplane was launched from the rear of the Conning tower.
        Could that be the torpedo launcher right there sticking out from the side of the stern between the two boats?
          The Surcouf is in the background. Hold down the control key and zoom in and you will notice the name "Surcouf on the side of the hull on the left of the picture. Now , notice the darkened area just to the right of the name. That is a rotating panel attached to a torpedo mount that pivots and rotates out. Notice these next pictures of other French subs that use the same system.
ID:	63064Click image for larger version
ID:	63063Click image for larger version
            This picture actually says surcouf 1929
ID:	63061Click image for larger version
ID:	63060Click image for larger version
ID:	63059Click image for larger version
              You can see here the various torpedo banks on this French submarine. Very similar to the Surcouf.
ID:	63089Click image for larger version
ID:	63088Click image for larger version
ID:	63087Click image for larger version
                If you look at her stern from this angle you can see two rectangular darkened areas just forward of her stern and just below her rear deck. Those are the openings for the aforementioned torpedo launchers.
                • Mankster
                  • 41
                  Is that last picture an actual photo of the boat, or is it a model/ CGI? The gun casing is completle different from the the other photos. Looks a little wide and out of proportion.
                    Mankster, As far as I am aware , it is an actual picture. However it may be somewhat distorted due to the angle that we are seeing the boat as well as possible picture compression by someones software. Keep in mind that this is an old picture that has been saved and copied and saved and copied countless times.
Name:	surcouf front quarter.jpg
ID:	63105Click image for larger version
Name:	surcouf engines.jpg
ID:	63104Click image for larger version
Name:	surcouf gun barrel.jpg
ID:	63103Click image for larger version
Name:	surcouf gun inside.jpg
ID:	63102Click image for larger version
Name:	surcouf from front.jpg
ID:	63101Click image for larger version
Name:	surcouf gun front.jpg
ID:	63100Click image for larger version
Name:	surcouf and parthian front.jpg
                      Surcouf left , Hms Parthian right
Name:	surcouf inside.jpg
ID:	63112Click image for larger version
Name:	surcouf sail rear.jpg
ID:	63111Click image for larger version
Name:	surcouf internal.jpg
ID:	63110Click image for larger version
Name:	Surcouf machine gun.jpg
ID:	63109Click image for larger version
Name:	surcouf ladder.jpg
ID:	63108Click image for larger version
Name:	surcouf hi res.jpg
ID:	63107Click image for larger version
                          Shoot, weve got enough info now that we could build our own.Click image for larger version
Name:	surcouf welding.jpg
ID:	63114Click image for larger version
Name:	surcouf side distant.jpg
                            Look at these two pictures and look all the way to the stern and magnify. What do you see sticking out?Click image for larger version
ID:	63116Click image for larger version
                              You see this.Click image for larger version
