New info on surcouf
  • Peewee
    • 15
    #31
    This is very true, but when youy look here http://www.otwdesigns.com/submarines...f/Surcouf.html what can one do?
    Ian
    Sane? who knows, who cares?
      OH! Now I understand. They make good boats by the way.
        At 1:72 scale the boat is 5' long, which, to me, seems a more reasonable length.
          • 14011
          #34
          And a more 'common' scale to boot. A good match for a lengthened GATO SD.
            I have some molds for the Surcouf at 1:72nd scale.
            So far, I have just one hull finished. I'll get around to dive planes, rudder etc shortly. If someone is keen to get going on a Surcouf, and they are a model maker, then this is a great hull. I have all the plans and loads of photos.
            $275.00 gets you the hull and conning tower.
            Note there are three hull sections. The two on the left can be joined together to make a complete boat, then cut to suit. Or, the right hand section allows the two hull to be cut along the waterline, and this top section is already made for you.
              For props, I have deduced the Raboesch models are the same as for the British MBD T & S class
              R176-03 1.4 3/16 3 blade R/hand 10000 rpm $16.00
              R176-04 1.4 3/16 3 blade L/hand
              Has anyone noticed that the starboard prop is set for'ard of the port prop?
                Check out this page:http://bernews.com/2011/10/mystery-o...aving-bermuda/
                  Heres a model by Paul Drake. In one view it is being attacked by a model of a Short Sunderlin.
Name:	Pat Drakes simulated attack.jpg
ID:	67451Click image for larger version
Name:	Pat Drakes Surcouf.jpg
ID:	67452Click image for larger version
Name:	Pat Drakes Surcouf firing guns.jpg
                    Large, high resolution picture. Click once on the picture to see the whole thing.Click image for larger version
Name:	Surcouf large.jpg
                      Did a blow up of the above picture.
                        Heres a few close-ups.
Name:	Surcouf close.jpg
ID:	73923Click image for larger version
Name:	Surcouf close bridge.jpg
ID:	73924Click image for larger version
Name:	Surcouf torp launcher.jpg
ID:	73925Click image for larger version
Name:	surcouf guns close.jpg
ID:	73954Click image for larger version
Name:	Surcouf sail rear.jpg
ID:	73955Click image for larger version
Name:	Surcouf sail rear1.jpg
ID:	73956Click image for larger version
                          • herrmill
                            • 360
                            #43
                            Nice photos I've not seen before. Like every other cruiser sub before it, I always felt it was better suited for marine reviews than actual operational use but still an interesting subject.
                              Here is another picture that I just picked up and zoomed and enhanced.
ID:	74613Click image for larger version
Name:	Surcouf mid zoom.jpg
ID:	74614Click image for larger version
Name:	Surcouf zoom-001.jpg
ID:	74615Click image for larger version
Name:	surcouf zoom forward.jpg
                                OTW has come out with an 87" long model of the Surcouf. On the cover and inside are pictures and a story behind Ken Griffins build of it. Here are a few pictures that I ..............squeezed out of the Dec. issue of the SCR.
Name:	Ken Griffin Surcouf.jpg
ID:	75135Click image for larger version
Name:	surcouf back up.jpg
ID:	75137Click image for larger version
Name:	Ken Griffen Surcouf edit.jpg
