1:96 Scale Russian Kilo Kit Build
    • 1936
Name:	Russian Kilo Kit.jpg
ID:	158079Click image for larger version
Name:	70 mm WTC.jpg
    This is the 1:96 scale Russian Kilo kit and 70 mm WTC that I purchased from Nautilus Drydocks!
Name:	Russian Kilo 1.jpg
    The photo above shows the hull and the components that come with the kit! It's my understanding that David M. did a lot of the accessories that came with this kit. I will be posting up photo as I make progress on this boat. This will not only be my first real diving boat, but it will also be somewhat of a break-away for me from 3D printed hulls. I will have to acquire another learning skill to build this boat. I am sure I will be asking a lot of questions. I am really looking forward to this build!
    • 1936
    I have done a little prelim. work on the hull sections.
Name:	Kilo Hull View.jpg
ID:	158101Click image for larger version
Name:	Kilo Hull 1.jpg
Name:	Kilo Hull 2.jpg
    I am new at working with this type of material, so I will have a learning curve for sure. I do know one thing for sure, and that any cutting or sanding will be done outside and with a mask for sure.
    As you can see the hull is not coming together at this point. Cutting and sanding will be in my future for sure! (I just love 3D Printing) :-) I will get it done with some forethought and being patient with the process!
      • 1936
      QUESTION: What type of health reactions should I be aware of working with this fiber glass hull? I just made a cut into the hull with a razor saw. I had a N-94 mask on, long pants, long sleeve shirt. With-in mins. my skin broke out with a bad rash! Has anyone had this situation working with this type of material?
        • 13653
        The glass is not the issue. The cured resin -- now in aerosol size chunks is. Is it polyester or epoxy laminating resin the manufacturer uses to lay up of the KILO's GRP parts? Once you know, look up the OSHA data on that stuff.
        Never bothered Ellie or me and we inhaled decades worth of shop dust and fumes. I don't think we can pin her cancer on it, her lungs were clean. Most allergic reactions originate with the uncured, but catalyzed resin, not the cured stuff. And that's not your situation here.
        So, Ron, there you have it, a focus group of two.
          • 821
          Rob, I have never had any reaction to the dust from cutting or sanding either polyester or epoxy resin but everyone is different. Was the rash just on your hands? If so, you may just want to put some gloves on along with the mask and long sleeves etc. It's always good to learn to work with different mediums.
            • 1936
            Thank you for the information, David. For now, I will continue to cover up as much as possible. It's for sure I will be outside with it during that fitting process. That would be a shame if I could not do this build. I will take the necessary precautions and see how it goes
            Lorraine and I are so sorry to hear about Ellie!
              • 13653
              Ellie had a good run. Left nothing but smiles in her wake. Modern medical care kept her going, and comfortable to the end.
              No one gets out of here alive. Make hay while you can.
              • vital.spark
                • May 2010
                • 307
                David, I didn't realize that Ellie had passed. She was so delightful to be around and both Fanny and I always had smiles on our faces when being with her!
                  • 13653
                  She did that, didn't she. I was one lucky SOB. We so enjoyed your visit and good company. You still two-wheeling it around the world?
                    • 1936
                    Hi Steve,
                    I will do my best to keep covered up. Another lesson learned. I do have another question. Can you apply heat to polyester or epoxy resin hull to shape them a little?
                      • 821
                      Yes, but carefully. On a hull as thin as the Kilo the heat from a standard hair dryer may be sufficient. I have heard where some will band/brace the hull and leave it set in the sun for a bit. My Nautilus hull was pretty badly warped when I got it and after some coaxing and a significant amount of heat from a heat gun I was able to get the top and bottom to mate back up pretty darn good but it is a considerably thick Polyester hull.
                        • 1936
                        Thanks Steve,
                        Today I will start the cutting and sanding and start bringing the two sections together. I feel confident that with a little finessing it will come together, and if a little heat will help i will certainly go slow with thar process for sure. Thanks again for the advice Steve.
                          • 13653
                          Thanks Steve,
                          Though it's the BLUEBACK kit, it does demonstrate how the forward and after ends of the KILO kit goes together:
                            • 1936
                            Thank you for the photos, and the information on the Blueback kit.
ID:	158158Click image for larger version
                            Photos above are before, or how the Kilo kit came to me.
Name:	Kilo Hull Joint 3.jpg
ID:	158160Click image for larger version
Name:	Kilo Hull Joint 2.jpg
Name:	Kilo Hull Joint 1.jpg
                            The photos above show what I was able to get done today. I guess I am making head way!
                              • 1936
                              I also drilled the pilot holes for the hull bottom vents. I just need to file them to the correct rectangular shape!
Name:	Kilo Hull Holes 1.jpg
