Towed Camera
    • 803
    Towed Camera
    I was very impressed with the towed camera rig that David M. had at Subfest so I did a little searching and decided to try a Drift Ghost X camera in a waterproof case.
    Click image for larger version  Name:	20211026_124134.jpg Views:	13 Size:	47.9 KB ID:	155005
    Click image for larger version  Name:	20211026_124112.jpg Views:	11 Size:	43.2 KB ID:	155006
    It is bigger of course than what David has and I am not worried about putting it in a waterproof tow vehicle for obvious reasons so I designed and printed this to try out.
    Click image for larger version  Name:	20211026_110859.jpg Views:	12 Size:	60.3 KB ID:	155007
    Click image for larger version  Name:	20211026_110841.jpg Views:	11 Size:	46.0 KB ID:	155008
    It should be no problem for my bigger boats to pull so I am eager to try it out soon.
    • 12320
    Beautiful, Steve!
    the tow point is on the bottom, just forward of the lens, but out of the field-of-view. Ballast it to be just a smidgen positively buoyant. The low tow point will make the body pitch up as you speed up the towing vehicle so cant the stabilizer down a bit to counter that. That's why mine has an aluminum boom -- easy to bend for such adjustments.
ID:	155015Click image for larger version
ID:	155016Click image for larger version
ID:	155017Click image for larger version
ID:	155018Click image for larger version
    Here's a variation on the theme:
ID:	155010Click image for larger version
ID:	155011Click image for larger version
ID:	155012Click image for larger version
ID:	155013Click image for larger version
    Well done, sir. ​​​​​​​
      • 803
      Good to know on the aluminum spar. Right now it is carbon fiber but can easily be changed. I have not yet mounted the tow point to it so good to see where you have yours. Thank you.
        • 2121
        As you have some vanes inside the circular ring, perhaps you could make the lower ones pitchable with some copper wire hinges.
          • 12320
          Listen to this man -- he's the guy who manufactured and so kindly provided me with the tow-body I talk about so often. A magnificent little example of Craftsmanship.
            • 803
            I have thought of that. Wouldn't be difficult to do. Definitely worth considering. Thank you.
