Towed Camera
  • SubDude
    • 825
    Towed Camera
    I was very impressed with the towed camera rig that David M. had at Subfest so I did a little searching and decided to try a Drift Ghost X camera in a waterproof case.
    Click image for larger version  Name:	20211026_124134.jpg Views:	13 Size:	47.9 KB ID:	155005
    Click image for larger version  Name:	20211026_124112.jpg Views:	11 Size:	43.2 KB ID:	155006
    It is bigger of course than what David has and I am not worried about putting it in a waterproof tow vehicle for obvious reasons so I designed and printed this to try out.
    Click image for larger version  Name:	20211026_110859.jpg Views:	12 Size:	60.3 KB ID:	155007
    Click image for larger version  Name:	20211026_110841.jpg Views:	11 Size:	46.0 KB ID:	155008
    It should be no problem for my bigger boats to pull so I am eager to try it out soon.
    Beautiful, Steve!
    the tow point is on the bottom, just forward of the lens, but out of the field-of-view. Ballast it to be just a smidgen positively buoyant. The low tow point will make the body pitch up as you speed up the towing vehicle so cant the stabilizer down a bit to counter that. That's why mine has an aluminum boom -- easy to bend for such adjustments.
ID:	155015Click image for larger version
ID:	155016Click image for larger version
ID:	155017Click image for larger version
ID:	155018Click image for larger version
    Here's a variation on the theme:
ID:	155010Click image for larger version
ID:	155011Click image for larger version
ID:	155012Click image for larger version
ID:	155013Click image for larger version
    Well done, sir. ​​​​​​​
    • SubDude
      • 825
      Good to know on the aluminum spar. Right now it is carbon fiber but can easily be changed. I have not yet mounted the tow point to it so good to see where you have yours. Thank you.
        As you have some vanes inside the circular ring, perhaps you could make the lower ones pitchable with some copper wire hinges.
          Listen to this man -- he's the guy who manufactured and so kindly provided me with the tow-body I talk about so often. A magnificent little example of Craftsmanship.
          • SubDude
            • 825
            I have thought of that. Wouldn't be difficult to do. Definitely worth considering. Thank you.
