Recent uboat pictures
Carl was only in his 50s then. That leather coat definately is restrictive, I have the same one and its worse when its wet. Especially on a motorcycle in the rain. Its odd that you mentioned loss of agility with age. I was just aboard my son's ship, a Ticondaroga class Cruiser. Im 70, and it was easy to go down 5 decks thru the hatches and ladders, just as natural as I use to do, skipping steps and sliding down on the rails. However going back up from crews bearthing to the top deck of the superstructure, I double stepped the first two levels, then slowes down. Especially if you have to stop and secure every other hatch you go thru. The tidal flow at my dock has a large effect on how I secure my boats. Right now we have the "Super Moon" summer solstice tide which has the greatest deviation of the year. The high tide comes over the deck, and the low tide you see all the barnicles and growth on the pilings. Its only about a two meter differance but the main floor of my house is only 3m MSL. And yes, I have had the ocean in the living room before, sorry to say. If the wind is blowing on shore with any force and a couple planets line up with the solar and lunar pull, we get water. Of course were on a verry small island, so no matter which direction the wind comes, its onshore somewhere all the time.Leave a comment:
I know what you're talking about, but time has passed since he was a line officer (agility is not the same, and less with a full dress). Regarding to planks, I remember what used to happen in places with big tide amplitudes, like Puerto Madryn (Golfo Nuevo, Argentina) with tide amplitudes bigger than 6 metres. We were the whole day dealing with the gangway, changeing it from main deck to a deckhouse deck. Some times you have to climb to board and other have to descend almost vertically.Leave a comment:
The picture of the forward tower mounted twin 2cm flak indicates that its from U 33. It is not. The U 33 was a type VIIA that was sunk in Feb 40. The VIIA towers were completely different than the VIIB and C. The Cs and Bs had the helmsmans port hole in the controll room as in the picture. The A models had a different placement of the perriscopes. No port hole below the lower splash shield. The magnetic compass housings, The little "dog house" in front of the tower, were different as well. The As were wider and lower than the Bs and Cs. The twin mount C-30 in the LC-30/37mount flak were not introduced until summer of 43. U33 only completed 3 patrols. Heres another, rare color view of 33on her last patrol with no flak fwd and single mount aft. Note: No lower splash shield either
Reddevil, of course its dangerous and unsafe, the U Boats themselves were "dangerous and unsafe" Not to worry about Uncle Carl, He got his sea leggs 20 years before. Actually it was standard procedure to lay the gangplank on the top of the railings when transferring from a larger ship with higher gunnels or some of the high seawalls in the larger ports. Thats a fancy plank compaired to some of the 35cm wide boards they sometimes used. He does look a bit concerned or focused. Might be timing his step with the up and down of the boat. The other guy, is most likely Heinrich Lieb, the captain, looks like he tripped or is ducking under the wire, in a hurry to get around the gun and help steady the plank. That was his last patrol when he got the Knights Cross with Oak Leaves presented by Carl that day for sinking 8 ships, 47,279 tons off of Africa on that patrol. The picture of U31 on its side has a good view of the unique deck layout on the type VIIA. It appears the extended perriscope has been bent. U31 was the first boat to attack the first convoy OB-Y Sept 39. It was sunk in Jadebusen by RAF bombers on March 11 1940 with all hands (58) lost. It was raised later that month and put back in service(possibly that picture is after raising) It was sunk again north of Ireland by RAF in Nov 40 2 dead 44 survivors.Last edited by Von Hilde; 06-22-2013, 06:07 AM.Leave a comment:
Don't miss Uncle Karl's face when trying to jump up the gangway. Gangway's position on tower's handrail seems quite unsafe and doesn't have its own handrails mounted either.Leave a comment:
You guys are posting great photos, and the narrative is most informative. You've taken me back to school. Keep it up, please.
MLast edited by Outrider; 06-23-2013, 05:06 AM.Leave a comment:
Ahh! some good rare detail shots. U 25 was a type I. The overall design looked like it would have been a good boat, but the operational faults overcame its looks. Ive gone ahead and decided to turn my 1/24 type II into a Mere Noir after seeing all thes pics of the 2s. I got the dremmel saw out and have done some chopping on the tower for the wintergarden. According to the u boat dkm archives, all the type IIs that were operationally deployed after 43, except the training boats, were equipped with the extra twin 20cm flak mounts fore and aft. However most got the twin mounts but only, a few had two guns on each station. The IIDs replaced the forward Flak mount with a 195mm deck gun and had twin 20s in the wintergarden. Not many pics of the IIs after 44 as most were lost after May 43. I have contacted Mr Kolay of the Turkish Meritime Museum, and he is going to send me some pictures that the museum has of the German boats they had. Perhaps some my be ones that havent been published as of yet. Apparently quite a few modifications were made in Istanbul when the boats got there before they deployed in the Black Sea. It would be wonderful if they have some pictures of the construction stuck away somewhereLeave a comment:
Mr Warpatroler, you are correct about the adding of the limber holes on 18. here she is on the barge on her side along withu20. I wonder why they opened the keels. Perhaps more lead balast to compinsate for the added weight above the waterline. I was noticing the different cone style forward gun mounts in lieu of the old drum shaped on some of the Black Sea boats as well. Heres a shot of the torpedo busting the red star emblem you spoke of
After looking closer at the picture of the lookouts on the bridge, I notice the gun mount is a post 43 with the off set shoulder pads. This mount was designed for twin 2cm flak. This mount has only one gun on the gunners left. its mounted perpindicular so the magazine extends on his left side. Normally the right side gun is mounted sideways to facilitate the magazine on top. This was so the gunner could replace magazines with the left hand while the right hand pulled the trigger lever on the handlebar. I also see that there is a magazine ready box attachment on the transverse counter weight. Griffon models make a real accurate 1/72scale photo etched brass set fot the Zwieling mounts, with the early and late bases for the u boats and shnellboat. A real P.I.A. to put together but look real nice when done. A nice scratch built mod to put on a special Navy type IIA tower. Or better yet go big and do a sheerline.Last edited by Von Hilde; 06-16-2013, 05:44 AM.Leave a comment:
the RDFs all retracted but in different places. Check out U 10 next to 18 and 13 and the boat behind it> their antenna are mounted forward on the step of the tower. The ones that were inside the tower were recessed into the bulkhead. Heres a picture of U 23 (left)on its side on a barge on the way to Istanbul. Note the limberholes wernt changed as is the boat on the right either. The pic of the boat with the Black Sea cammo up top is mis captioned as 18. It is U23, Note no aft flakHere is U 9, one of the Black Sea boats with the antenna forward. as opposed to the recessed in tower on another type II
Of the 6 boats that went, 9, 18 and 24 the Russians raised off of Romania and were re sunk by target pratcise in 46. 19, 20 and 23 are still preserved on the bottom of the Northern Turkish coast. U 18 U19 and 20 had 2cm zwiling. Twin mounts added after Istambul. U 23 was a single mount
U 19 Istanbul, notice the twin barrels behind the seaman at parade rest on the wintergarden aft.
