How do you chop Seaview's top?
  • Tugfan
    • Nov 2010
    • 178
    How do you chop the top on Seaview for RC without making a mess of it?
    One thing that you might consider is cutting out the bottom so everything rests on a tray. Just a thought. The only thing that might get in the way of this might be hooking up the drive shafts and linkages.
    • ADDINGTON
      • Sep 2008
      • 80
      Which Seaview model/hull ?
        • 3554
        You're pertaining to the Mobieus model right? Isn't that particular model's hull designed to plug together? Some modelers utilize this feature to install the wtc inside the hull. They just cut off the top part of the stern to facilitate connecting the prop shaft and linkages.
          • 13741
ID:	61481Click image for larger version
ID:	61482Click image for larger version
            • 13741
ID:	61489Click image for larger version
ID:	61488Click image for larger version
ID:	61486Click image for larger version
ID:	61484Click image for larger version
            • Tugfan
              • Nov 2010
              • 178
              I know where to cut, I need to know what to use. Blade? Saw?
                • 3554
                You can use both. Either a dremel with a cutting disc. You'll need to make a jig to hold the dremel at a constant height. If you don't have a dremel you can try doing it manually with a no.11 blade and some dymo tape or even a section of a metal tape measure (curved surface of tape helps conform to curvature of hull). You stick the tape along the edge of the cut as a guide. Use light strokes.
                  • 13741
                  No, no, no! You're thinking GATO. We're decapitating the SEAVIEW here!
                  #11, right into the seam between superstructure and hull, medium pressure passes till you punch through. No kerf, no muss, no fuss.
                  YOU PEOPLE!
                  • Tugfan
                    • Nov 2010
                    • 178
                    Thanks, Dave. Now, about your Skipjack..............:pop
                      • 13741
                      A teaser for you. The shots are of 'my baby', I've packed it off to China. Guess what their going to do with it?!
                      Stay tuned, sports fans!
ID:	61522Click image for larger version
ID:	61525Click image for larger version
ID:	61524Click image for larger version
                      • Rpmtech1
                        • Dec 2009
                        • 229
                        Steal it's design and lose your contact info? Ha!
