Storing the sub driver unit
    • 3560
    What's the ideal way of storing a SD unit, with the endcaps on or off?
  • Slats
    • 1776
    I open it all up. (End caps off)
    Each SD has its own dedicated craddle, and a pillow case to keep dust off.
    There then packed neatly into a storage cupboard.
    J.
    sigpic
      • 3560
      My concern here would be the O-ring seals. Would it deform and prevent sealing if the endcap is left in for a prolonged time?
      • Slats
        • 1776
        Dunno
        The Wizard will tell you.
        sigpic
          • 651
          They will take on a deformed set, so yes it is good protocol leave in open.
            • 13745
            nope ...........
              • 651
              stands corrected
