Depth Cruiser
  • DMTNT
    • Jun 2018
    • 297
    Depth Cruiser
    Evening All. Would anyone with some experience using Kevin McLeod’s Depth Cruiser mind sharing their thoughts / opinions of it? Seems like a slick setup. How did you go about fabricating the pressure pick-up tube? I was considering mounting a 2.25” vertical length of 1/8” or 3/32” brass tube to the exterior forward bulkhead of my SD, then connecting it via 1/8” urethane tubing to a nipple that will penetrate an unused depression in the after bulkhead, and onto the DC inside.
    Bob, I don’t know if you’ll see this - but is there any chance I could buy a 3’ length of gray Clippard tubing from you? The manufacturer is tied up supporting ventilator production.
    Thanks guys. Stay healthy.
    -Brady
    Dead men tell no tales...
    • 1981
    No problem at all. I got your direct message. We'll get you hooked up.
    DC only needs access to the exterior of the cylinder. No need for extensions. Just a hole. A simple nipple made from brass tube is all you need.
    • DMTNT
      • Jun 2018
      • 297
      Oh really? Interesting.... I saw a picture of a SD that David had a depth cruiser installed on and that’s what I thought I saw. I’m very excited to get this hooked up and see how it does.
      Thank you for the help, Bob!
        • 13629
ID:	138396Click image for larger version
ID:	138397Click image for larger version
ID:	138398Click image for larger version
        • DMTNT
          • Jun 2018
          • 297
          Got it. Thanks David!
