today's work
    • 13983
    #3121
    • DrSchmidt
      • Apr 2014
      • 1393
      #3122
      The shaft supports look great.....
        • 13983
        #3123
        Need some work chopping off all the vent-risers, but I think you're up to it, sir. Should have all your masters and parts off this week.
          • 13983
          #3124
            • 13983
            #3125
            • DrSchmidt
              • Apr 2014
              • 1393
              #3126
              Looks fantastic!
                • 13983
                #3127
                  Looks like this is the way to go with RCing the Das Derk 1/72 U-9.
                    • 13983
                    #3129
                    Just one of many possible ways.
                      Dave, I’m always afraid of putting stress on the entrance/exit of the servo linkage while bending them, causing damage to the gasket. I use another pair of holders on the exit to ensure I don’t. You make it look easy and unnecessary. Also, I’ve never seen you slip that cut out WTC on when you bend the linkage. That’s a new one on me.
                        • 13983
                        #3131
                        I have the complete range (diameter) of those 'linkage/pushrod integrating jigs' but this appears to be the first picture I've posted of one being used.
                        Though I'm long out of production-mode of WTC assembly, I still break out the relevant tooling, jigs. fixtures and documents (not lost in the flood) when the need arises.
                        What was once a business is now again a hobby.
                          Do you find the Z bend always the easiest to use, and does it have the best range of motion?
                            • 13983
                            #3133
                            Good range of (rotational) motion, marginal anti-back-lash. But good enough for us. Chosen because I'm from the school of, 'don't permit perfection to become the death of accomplishment'. If it works, don't fix it.
                              • 13983
                              #3134
                                • 13983
                                #3135
