Announcement
Forum rules and expectations
Hello, and welcome to the forums at the Nautilus Drydocks, formerly Sub-driver.com!
We welcome anyone with a passion for submarines and a desire to learn and share knowledge about this fascinating hobby. Use of these forums indicates your intention to abide by our code of conduct:
1. No spam. All automated messages, advertisements, and links to competitor websites will be deleted immediately.
2. Please post in relevant sub-forums only. Messages posted in the wrong topic area will be removed and placed in the correct sub-forum by moderators.
3. Respect other users. No flaming or abusing fellow forum members. Users who continue to post inflammatory, abusive comments will be deleted from the forum after or without a warning.
4. No threats or harassment of other users will be tolerated. Any instance of threatening or harassing behavior is grounds for deletion from the forums.
5. No profanity or pornography is allowed. Posts containing adult material will be deleted.
6. No re-posting of copyrighted materials or other illegal content is allowed. Any posts containing illegal content or copyrighted materials will be deleted.
See more
See less
To HWSNBN Your old Torpedo Breech Tech. Question
  • Filter
  • george
    Again Thank You for this last bit of information and pictures. IT will help me a lot!!!!!!!!
    Thanks for your help.
    George
    Originally posted by george View Post
    Thanks That helps BUT I was also curious as to what outside diameter tube you used for each scale torpedo; 1/96 and 1/72. I have made a breach for the 1/72 with 1/16" O ring with a snug fit BUT NOT sure for the 1/96 what the rear tube of the torpedo outside diameter is so I can figure out what O ring that needs or is it the same O ring ?
    George
    Both employed a 1/16" o.d. aluminum tube that received a nozzle plug of CA that was drilled to a throat diameter of .008". Still too large a throat as the weapons went too fast to be stable. Could not find a commercially available drill bit smaller. So, end of the road for me.
    Had to move on to more viable commercial enterprises. Too bad. I was almost there. Bob has the ball now and I think he's just about perfected things.
  • george
    Originally posted by He Who Shall Not Be Named View Post
    I assume you mean the torpedo tube inside diameter? If so, no. Two different diameters. However both the 1/96 and 1/72 weapons employed the same .008" exhaust nozzle. Which by the way, was the smallest drill bit I could find, but was still too large as my weapons go too damned fast in the water which makes them subject to broaching during the run.
    Glad to help, George. Anytime.
    George
    Are both breeches the same size and are the tail end exhaust tubes the same size also?
    Also
    Thanks for your Time and Help with this.
  • george
    Also
    Hello Sir
    I was wondering reg. your old 1/72 breech section and torpedo aft gassing tube and the your 1/96 torpedo aft gassing tube and breech. Are they both the same size of breech and aft gassing tubes?
    Can you remember or can you find out what the size of your brass plug insert was that was used to make your cavity space in your 1/72 and 1/96 torpedos?
    Thanks for your Time and Help.
    George
    The core for the 1/72 torpedo is 7/32" diameter. The core for the 1/96 torpedo is 3/16". Sorry for the delay, they were berried in the shed.
  • george
    started a topic To HWSNBN Your old Torpedo Breech Tech. Question
    Hello Sir
    George
