To HWSNBN Your old Torpedo Breech Tech. Question
  • george
    • Dec 2010
    • 727
    Hello Sir
    I was wondering reg. your old 1/72 breech section and torpedo aft gassing tube and the your 1/96 torpedo aft gassing tube and breech. Are they both the same size of breech and aft gassing tubes?
    Can you remember or can you find out what the size of your brass plug insert was that was used to make your cavity space in your 1/72 and 1/96 torpedos?
    Thanks for your Time and Help.
    George
    • 12290
    Originally posted by george
    Hello Sir
    George
    The core for the 1/72 torpedo is 7/32" diameter. The core for the 1/96 torpedo is 3/16". Sorry for the delay, they were berried in the shed.
    • george
      • Dec 2010
      • 727
      Are both breeches the same size and are the tail end exhaust tubes the same size also?
      Also
      Thanks for your Time and Help with this.
        • 12290
        Also
        I assume you mean the torpedo tube inside diameter? If so, no. Two different diameters. However both the 1/96 and 1/72 weapons employed the same .008" exhaust nozzle. Which by the way, was the smallest drill bit I could find, but was still too large as my weapons go too damned fast in the water which makes them subject to broaching during the run.
        Glad to help, George. Anytime.
        • george
          • Dec 2010
          • 727
          Thanks That helps BUT I was also curious as to what outside diameter tube you used for each scale torpedo; 1/96 and 1/72. I have made a breach for the 1/72 with 1/16" O ring with a snug fit BUT NOT sure for the 1/96 what the rear tube of the torpedo outside diameter is so I can figure out what O ring that needs or is it the same O ring ?
          George
            • 12290
            George
            Both employed a 1/16" o.d. aluminum tube that received a nozzle plug of CA that was drilled to a throat diameter of .008". Still too large a throat as the weapons went too fast to be stable. Could not find a commercially available drill bit smaller. So, end of the road for me.
            Had to move on to more viable commercial enterprises. Too bad. I was almost there. Bob has the ball now and I think he's just about perfected things.
            • george
              • Dec 2010
              • 727
              Again Thank You for this last bit of information and pictures. IT will help me a lot!!!!!!!!
              Thanks for your help.
              George
